I have a 5 V 10 Amp relay module and a Raspberry Pi 3. I am using it to connect to a submersible pump which runs on AC power. Can I use the 5 V GPIO pin of the Raspberry Pi or do I need to buy a DC adaptor?
Asked
Active
Viewed 92 times
-1
2How much current does the spec sheet of this anonymous module say it needs? – Milliways Jun 16 '17 at 06:02
It seems that there is another question regarding this topic https://raspberrypi.stackexchange.com/questions/34512/what-things-i-can-use-for-turning-on-a-relay?rq=1 – LouiBazz Jun 20 '17 at 02:47
The module is rated 5 V 10 Amperes – Shreyas Mishra Jun 22 '17 at 04:44
Does this answer your question? What things I can use for turning on a relay? – Dougie Mar 20 '21 at 16:54
I'm not sure you have a clear understanding of what's going on. Or perhaps I can't read what you wrote.
You need an AC->DC converter. This is not negotiable. Whatever you give power to the Pi through the USB or the +5V pin changes little. Decent industrial 220VAC -> 5VDC converters for this power can be as little as 10 bucks. 220VAC to pi = BOOM.
You will need a supporting relay board.
MaxDZ8
- 329
- 7
