I have a project with a raspberry pi zero w, and his camera, and I want to have a video stream and with less delay as possible, and if possible, a stream which can be started with a bash script. Thanks for answering
Asked
Active
Viewed 4,649 times
1Have a look at motioneyeos https://github.com/ccrisan/motioneyeos/wiki – Steve Robillard Jun 09 '17 at 11:59
@SteveRobillard is there an other way with raspbian ? – Jangberry Jun 09 '17 at 12:38
if you're looking for an open source solution uv4l is not your friend.
Instead have a look at:
sparkie
- 435
- 3
- 9
I think you are lookking for uv4l
This program offer a built-in web server, allowing camera configuration, live stream with low latency and decent fps, low CPU consumption, and some extra features that may, or not, fit your specific needs.
I tried some other solution (ffmpeg, gstreamer), and I think that uv4l, being a userspace driver level, is the most performant tool for this.
And it's easy to use :)
Look at the demos to see implementation samples
Technico.top
- 1,406
- 13
- 20
