Hello I've tried to see the preview of picamera via both VNC viewer and SSH from my mac, after I use something like camera.start_preview() I got
<picamera.renderers.PiPreviewRenderer object at 0x75cb0390>
but there is no screen shown the preview...
I use Raspberry Pi 2 Model B V1.1, OS X, I installed both python2 and 3.
Niing
  • 119
  • The camera preview is not sent over VNC, it can only be viewed on a monitor connected to the Pi. Since the camera preview is handled on a low level in the GPU. This might help you though. – Darth Vader May 30 '17 at 09:43
  • @DarthVader Thank you so much. How should I use if I want to see the camera preview directly in VNC? – Niing May 30 '17 at 09:51
  • If you're using the RealVNC server on the Pi, go to VNC options > troubleshooting and enable "experimental direct capture mode", then you'll be able to view the camera preview image over the vnc connection. – Andrew Wedgbury May 30 '17 at 11:30
@N1ng Personally its good if you use HDMI monitors or Displays for camera preview , Because the Preview is not supported in Pitft screens ,However for SSH See this
