Most Arduinos reset (that is, restart the sketch, clearing all data) when the serial connection is opened. So if there's no connection open, any data present before the connection is opened will be lost. There are ways around this, but they interfere with your ability to upload sketches.
The serial output buffer in an Arduino is very small: 64 bytes or fewer. If there were no system buffers, your Arduino sketch would hang, pausing all readings until the serial buffer is read.
Collecting data from the channel deletes it. If you want to see if data is there but not read it, the in_waiting() method returns the number of bytes in the receive buffer.
Update: so my previous answer was based on lots of ‘in theory’ assumptions. I thought I'd test what happens to unread data with a sketch that:
wrote an incrementing counter at 115200 bps;
indicated while the main loop was running by flashing an LED. If the LED wasn't flashing, the loop() subroutine in the sketch was hung up; and
indicated if the Arduino's serial output buffer was nearly full by lighting the internal LED. (This turned out to be less useful than I thought, because it's almost always nearly full.)
I then wrote a Python 3 program to open the serial port, read a few lines, pause for a few seconds, read a few more lines, pause for a longer period, then read some more lines. The results surprised me, especially with the differences between two types of (official) Arduino boards.
Arduino sketch
#define WARN_PIN 13 // built in LED
#define WARN_COUNT 4 // warn at this many bytes left
#define WORK_PIN 7 // alternate this to simulate “work” …
long count = 0;
boolean state = true;
void setup() {
pinMode(WARN_PIN, OUTPUT);
pinMode(WORK_PIN, OUTPUT);
Serial.begin(115200);
Serial.println("# Buffer Test Started");
void loop() {
Serial.println(count);
if (Serial.availableForWrite() < WARN_COUNT) {
digitalWrite(WARN_PIN, HIGH); // set warning LED if buffer nearly full
else {
digitalWrite(WARN_PIN, LOW);
count++;
if (count % 1000 == 0) {
state = !state; // every 1000 cycles change work led
digitalWrite(WORK_PIN, state);
The expected output from this sketch would be:
As with all Arduino sketches, each line is terminated by CRLF (\r\n). At a very rough estimate based on watching the LED on port 7, the sketch generated 1000 lines per second.
This sketch was installed on four Arduino boards: Uno R3, Mega 2560, Leonardo and also a cheap Nano clone.
Python Serial Reader
I tested several variants of the following code, testing a pause of ten seconds, a minute, ten minutes and finally an hour between reading from the serial port:
#!/usr/bin/env python3
# -*- coding: utf-8 -*-
import serial
import time
ser = serial.Serial('/dev/ttyACM0', baudrate = 115200, timeout = 1.0)
# read the first three lines
print(ser.readline())
print("## Sleeping for 5 seconds …")
time.sleep(5.0)
# read the next three lines
print("## Sleeping for 3600 seconds … zzz…")
time.sleep(3600.0)
# read three more lines
If the Raspberry Pi is buffering serial data correctly, the output lines should have consecutive numbers.
Results
The Uno R3, Mega 2560 and Nano clone all produced similar results. Here's the output from an hour pause on the Uno R3 connected to a Raspberry Pi 3, complete with initial line noise burst (and Python's weird obstinacy against do what I mean data type conversion):
b'\t\x86\x1a\xb4\x94\xa7\x96\xa7\x96\xa7\x96\x87\x96$\xb1\xc9\x1fb\x1b\xb3\x0b\x13\x13\x93\x13\xad\x16\x12\xa1\x12\xa1\xb6&\xb6\x1a\xb6\x96\xa7\x96\xa7\x96\x87\x964t\xb2\x0b\xb3\x133\x13\x93\x03\xa1\xd3\xf2}\xcdi\xcd\x0f`&`\x13-\x12\x88\x89\xa20\xb4\x94\xa6\x96\xa7\x96\xa7\x96\xa7\x96\x87\x96\x02\xe3a<@\xb0H\xb0@\xb1J\x1b-\x12\xc9\x89$\xa8\xa6\x94\xa6\x96\xa7\x96\xa7\x96\x87\x96\x07\x96\x03\xeb\xc9=@T\xb3\x1b\x93\x1b-\x16\x98\x8b$\xa2\xb51\xb4\x94\xa7\x96\xa7\x96\xa7\x96\x87\x96$\xb1\xc9\x1fb\x1b\xb3\x0b\x13\x13\x93\x13\xad\x16\x12\xa1\x12\xa1\xb6&\xb6\x1a\xb6\x96\xa7\x96\xa7\x96\x87\x964t\xb2\x0b\xb3\x133\x13\x93\x03\xa1\xd3\xf2}\xcdi\xcd\x0f`&`\x13-\x12\x88\x89\xa20\xb4\x94\xa6\x96\xa7\x96\xa7\x96\xa7\x96\x87\x96\x02\xe3a<@\xb0H\xb0@\xb1J\x1b-\x12\xc9\x89$\xa8\xa6\x94\xa6\x96\xa7\x96\xa7\x96\x87\x96\x07\x96\x03\xeb\xc9=@T\xb3\x1b\x93\x1b-\x16\x98\x8b$\xa2\xb51\xb4\x94\xa7\x96\xa7\x96\xa7\x96\x87\x96$\xb1\xc9\x1fb\x1b\xb3\x0b\x13\x13\x93\x13\xad\x16\x12\xa1\x12\xa1\xb6&\xb6\x1a\xb6\x96\xa7\x96\xa7\x96\x87\x964t\xb2\x0b\xb3\x133\x13\x93\x03\xa1\xd3\xf2'
b'# Buffer Test Started\r\n'
b'0\r\n'
b'1\r\n'
b'2\r\n'
b'3\r\n'
b'4\r\n'
b'5\r\n'
b'6\r\n'
The loop() progress indicator LED kept flashing throughout the hour-long pause. The Raspberry Pi successfully buffered the data and output the first lines without losing any. There wasn't any obvious trend in the size of system buffers (reported periodically using free) during the run, despite the test program buffering thousands of characters per second. As expected, the line count reset to zero if the serial test restarted, losing all previous data.
(As the OP is using a Nano, the clone I'm using isn't based on the official FTDI serial chip. It uses the much cheaper QinHeng Electronics HL-340 interface. If yours is a real one, there's a very slim chance your results will be different.)
The Leonardo behaved quite differently:
It did not restart on re-running the test program. Subsequent runs showed the numbers increasing monotonically.
The loop() progress indicator LED stopped flashing after a time, indicating that the main Arduino program did not keep running if output was blocked.
Despite these differences, the initial data lines were preserved by the Raspberry Pi's serial input buffer. What's not clear from this test is how much of the later data is lost through the Leonardo ‘pausing’.
Conclusion
For an Arduino Nano (and Uno/Mega, and very likely older Duemilanove too) the serial data appears to stay in the Raspberry Pi's serial buffer indefinitely until read.
Upon reading the serial data, it is no longer available to the user.
If the physical connection is disturbed, the serial connection program is restarted, or the Raspberry Pi crashes, the buffered serial data will be lost. One should read and store these data to somewhere less volatile as frequently as practical.
While the Arduino Leonardo (and very likely the Micro, which is also based on the same µc) does not reset on serial reconnection, it also seems to lock up unhelpfully if serial reading is not maintained.
Other types of Arduino boards (such as the newer ARM-based ones) may exhibit behaviour different even from the two sets of results here.
