I was looking this post and trying to make in on my Arch Linux x86_64 host, but without success.
I can't chroot inside and I've noticed that Arch doesn't have qemu-arm-static bins, and it looks that they can't be build because Arch doesn't support any static linking.
So did anyone made it working and how?
10robinho
  • 706
  • Hello! I did it on Arch linux using and wrote the steps here. – Jivings Apr 02 '13 at 18:07
  • Hi, thanks for answer! I tried that but somehow I get bad performance, almost as same as on raspi itself. I am looking to compile some bigger programs so I need cross compiler. Did you got any good performance with that? – 10robinho Apr 02 '13 at 18:29
  • @10robinho Are you using Arch Linux to compile, or are you compiling for Arch Linux? What is the OS of the computers being used? – xxmbabanexx Apr 02 '13 at 23:57
  • both Arch Linux, one on x86_64 one on raspi – 10robinho Apr 03 '13 at 03:06
  • You don't want to emulate the CPU with QEMU then. You just want a compiler. There's details of how to set that up here. Again my answer is for Arch Linux, but it should be distribution agnostic. – Jivings Apr 03 '13 at 06:45
  • Thanks, I've realized that, but I'm still unable to compile real programs. Please check this http://raspberrypi.stackexchange.com/questions/6761/cross-compiling-missing-packages – 10robinho Apr 03 '13 at 07:31
  • Have you solved this issue yet? If so, could you please create a self-answer and mark it as such. We are trying to get the Q:A ratio up and that would help us a ton. Thanks! – RPiAwesomeness Mar 03 '14 at 17:48
So,
after some time I spent getting my cross-compiling environment ready with Raspberry PI and Arch Linux, I've realized that QEMU is not good solution, for two main reasons:
  1. Static linking is not supported with Arch Linux
  2. It is slow, so there is no much point in cross-compiling in that way
Solution I decided to use is plain cross-compiling, without any emulators. It takes some time to configure and get used to, but it is definitely worth.
10robinho
  • 706
