I've been considering making a custom linux build for the Raspberry Pi for the sake of minimalism and performance.
It occurred to me that, perhaps, Raspbian headless might be as minimal as one can get without giving up some crucial functionalities unique to Raspbian/Raspberry Pi, besides the millions of man-hours the community has put into perfecting it.
If one should wish to create a custom linux distro for the Pi, what things should they keep in mind? Is there anything important that is sacrificed by default?
Even in the best case, is this is a step up or a step down when it comes to taking advantage of the Pi's hardware?
When it is all considered, is this even a practical endeavor?
Darth Vader
  • 4,206
  • 45
  • 69
Pipsqweek
  • 123
  • What's going to be sacrificed? Many hours of sleep... I suggest tinkering with current distributions to get a feel for how they work. Putting one together by yourself is going to be a lot of work. – Darth Vader May 18 '17 at 07:16
This depends what you mean by "minimal". If you mean, system load at boot, which is essentially about RAM and CPU usage when idle, then it is pretty close to a minimum. Getting nominal CPU usage (<1%) with an idle system is I think standard on any general purpose computer running a sane OS sans GUI, so the most significant issue is then just RAM.
I run Pi's headless with Raspbian or Fedora; with Raspbian I start from jessie-lite and just disable a few of the init services that I don't care about (I do pretty much the same with Fedora, although of course it requires some other work for use on a Pi).
Generally my RAM usage on a base system like this is 20-25 MiB. I've never tried to get it down less than that because it seems slender enough considering this is still really a general purpose computer running a normative, contemporary general purpose OS (in fact, I boot to console on my big linux machines and they can start at about the same point).
My general point is there's not much you need to do with jessie-lite if that's what you want.
However, if by "minimal" you mean the install size, I am sure there are a few things you could get rid of. Maybe you could even cut that 2 GB in half -- but this will not impact or improve the system performance. It will just save you some space on the card...until you start installing stuff, at which point I think you will find many of the "optional" things you got rid of sneak back in as dependencies.
goldilocks
  • 58,859
  • 112
  • 227
