I know there have been a lot of similar questions, but for the life of me I can't figure out what's wrong! I have a script that forwards a port via ssh tunnel, and it works pretty fine, and I want to run it as a service on startup using systemd. I already have other services running on my Pi as systemd services, and they work well, so I can't figure out why this one is not. I'm using Raspbian Jessie (server, no gui, headless Pi).
So, the unit file is as follows:
[Unit]
Description=SSH tunnel for DomoPro
After=multi-user.target sshd.service network.target
[Service]
Type=idle
ExecStart=/usr/bin/python /usr/bin/pyScripts/mkTunnel.py
ExecStop=/usr/bin/python /usr/bin/pyScripts/rmTunnel.py
StandardOutput=journal
[Install]
WantedBy=multi-user.target
and the python script, in case it's necessary, is as follows:
#!/usr/bin/python
import MySQLdb
from time import time,sleep
from subprocess import Popen,call,PIPE
import pycurl
from StringIO import StringIO
import json
from math import floor
print("DomoPro Tunnel Service")
def getSerial():
cursor.execute("SELECT value FROM config WHERE var='serialKey'")
cfg = cursor.fetchone()
return cfg['value']
def setPort(port):
sqlupdt = "UPDATE config SET value = '{0}' WHERE var='remotePort'".format(port)
cursor.execute(sqlupdt)
def savePID(tunnelPID):
sqlupdt = "UPDATE config SET value = '{0}' WHERE var='tunnelPID'".format(tunnelPID)
def clearPID():
sqlupdt = "UPDATE config SET value = '' WHERE var='tunnelPID'"
def getTunnelData(serialKey):
from urllib import urlencode
ans = StringIO()
serverURL = "server_address/phpfile.php"
data_post = urlencode({"serialKey": serialKey})
curl = pycurl.Curl()
curl.setopt(curl.URL, serverURL)
curl.setopt(curl.WRITEFUNCTION, ans.write)
curl.setopt(curl.USERAGENT, "Some custom useragent")
curl.setopt(curl.FAILONERROR, 1)
curl.setopt(curl.CONNECTTIMEOUT, 10)
curl.setopt(curl.HTTPHEADER,['Accept: application/json'])
curl.setopt(curl.POST, 1)
curl.setopt(curl.POSTFIELDS, data_post)
try:
curl.perform()
except pycurl.error:
return (False,False,False)
curl.close()
try:
data = json.loads(ans.getvalue())
except ValueError:
return False
else:
(auth,port,isActive) = data['auth'], data['port'], data['isActive']
if auth == "OK":
return (auth,port,isActive)
else:
return (auth,False,False)
def openTunnel(port):
if port:
tunnel = call(['ssh','-fNq','-o','ConnectTimeout=5','-o','BatchMode=yes','-o','StrictHostKeyChecking=no','-o','ExitOnForwardFailure=yes','-R','{0}:localhost:443'.format(port),'user@server'])
return tunnel
else:
return 1
def getpsPID():
objPID = Popen('ps -C "ssh -fNq" -o pid=', shell=True, stdout=PIPE, stderr=PIPE)
PID = objPID.communicate()[0].replace('\n','').replace(' ','')
return PID
def getdbPID():
cursor.execute("SELECT value FROM config WHERE var='tunnelPID'")
return cfg['value']
def makeTunnel():
Return Codes:
0: Ok
1: Failed
2: Not Active
3: Auth Err
4: Conn Err
print("Opening tunnel...")
serialKey = getSerial()
(auth,port,isActive) = getTunnelData(serialKey)
if auth == "OK":
if isActive:
setPort(port)
tunnel = openTunnel(port)
if not tunnel:
tunnelPID = getpsPID()
savePID(tunnelPID)
print("Tunnel open")
return 0
else:
clearPID()
print("Tunnel failed")
return 1
else:
setPort(0)
clearPID()
print("DomoPro Remote not active")
return 2
elif auth == "ERROR":
setPort(0)
clearPID()
print("Auth error")
return 3
else:
setPort(0)
clearPID()
print("Connection failed")
return 4
def checkTunnel():
print("Checking tunnel...")
dbPID = getdbPID()
psPID = getpsPID()
if psPID:
if dbPID != psPID:
savePID(psPID)
print("Tunnel open, PID:{}".format(psPID))
return 0
else:
clearPID()
print("Tunnel closed")
return 1
db = MySQLdb.connect( host="localhost",
user="user",
passwd="pass",
db="db")
db.autocommit(True)
cursor = db.cursor(MySQLdb.cursors.DictCursor)
tunnelState = checkTunnel()
if tunnelState:
tunnelState = makeTunnel()
ts = time()
while True:
currts = time()
if (tunnelState == 0 or tunnelState == 1):
timeoff = 120
if (currts - ts) > timeoff:
if tunnelState:
ts = time()
else:
diff = timeoff - floor(currts - ts)
print("Sleeping for {}s...".format(diff))
sleep(diff)
elif tunnelState == 2:
timeoff = 3600
ts = time()
else:
sleep(diff)
elif tunnelState == 3:
timeoff = 86400
ts = time()
else:
sleep(diff)
elif tunnelState == 4:
timeoff = 300
ts = time()
else:
sleep(diff)
cursor.close()
I also tried adding it to crontab using @reboot
to no avail.
The script works flawlessly when run from command line.
You may notice there's another script running on service stop
. It actually runs ok.
EDIT:
I followed Goldilocks' guide and wrapped the script like this:
#!/bin/bash
# Wrapper for mkTunnel.py
exec &>> /home/pi/log/tunnel.log
echo $(date)
# Fork/exec
exec /usr/bin/python /usr/bin/pyScripts/mkTunnel.py
) &>> /home/pi/log/tunnel.log
exit 0
And it runs ok, but since my python script keeps running in background, and I guess that systemd is expecting an exit code, it shows an error message Job for tunnel.service failed
. The journal shows the following:
Starting SSH tunnel for DomoPro...
tunnel.service start operation timed out. Terminating.
Failed to start SSH tunnel for DomoPro.
Unit tunnel.service entered failed state.
My current unit file is this:
[Unit]
[Service]
Type=forking
GuessMainPID=no
ExecStart=/usr/bin/pyScripts/tunnel.sh
StandardError=journal
[Install]
How can I tell systemd not to timeout (or not to expect an exit code)?
EDIT 2:
It's working!! I forgot to remove verbosity from ssh and that was causing it to remain open, not returning an exit status for systemd. Thanks @goldilocks ;)
StandardOutput
, have you bothered looking at (or expanding) that? You should also attachStandardError
, I imagine curl and some of those other python bits complain there on failure (unless of course you catch those exceptions and throw any message away...I'm not a python user but it looks to me like you do that at least once). – goldilocks May 17 '17 at 11:01ExecStop
script does run, so I just don't understand what's wrong. I'll give it a try with redirectingStandardError
to the journal as well to check for any errors, but it would really be a surprise since the script works pretty fine. – Christian Rodriguez May 18 '17 at 14:30( exec whatever ) &> /var/log/mine/whatever.log
and useType=forking
. You can then elaborate that wrapper (make sure the path is set appropriately, echo "hello world I'm here", etc). Systemd has tidier ways to do all that so hackish -- but I do get everything to work this way and it's easy to see where it went wrong if it doesn't. There is always a reason ;) Have you looked at the output fromsystemctl status whatever
? – goldilocks May 18 '17 at 14:40StandardError
and no errors are showing. I do believe that the script is not running. – Christian Rodriguez May 18 '17 at 14:41systemctl status
report should show a historical process tree and give you a clue about when what failed. It includes stuff that is not send to the journal. – goldilocks May 18 '17 at 14:42command not found
, etc. You need to have that level of debugging in place one way or another. – goldilocks May 18 '17 at 14:44active (running)
, and the process tree shows the script running and the PID for the python process. – Christian Rodriguez May 18 '17 at 14:45ps -p [pid]
). If it is -- there you go. You need to work more logging in. The bigger and more complex pieces of code I write, the more I've come to depend on that to streamline the debugging process. I'm sure I'm not alone in that, either, lol. If your process is running, you need to step through your code and find places for it to report significant changes in state (stages of initialization, etc.), even when nothing is wrong. – goldilocks May 18 '17 at 15:04
