PhoneHome
My phone acts differently, as all phones has some difference. A ping response only happens if the phone is awake. If the Pi is rebooted and the phone is in sleep mode, multiple pings will place its ip and mac addresses in the arp table, with 100% packet loss. I just learned that the arp
command is obsolete, ip neighbor
is used now.
pi@RPi0:~ $ ip neighbor
169.254.65.43 dev eth0 lladdr 64:31:00:00:00:00 REACHABLE
192.168.0.1 dev wlan0 lladdr ac:b3:00:00:00:00 STALE
fe80::aeb3:13ff:fe00:000 dev wlan0 lladdr ac:b3:00:00:00:00 router STALE
pi@RPi0:~ $ ping 192.168.0.22
PING 192.168.0.22 (192.168.0.22) 56(84) bytes of data.
From 192.168.0.10 icmp_seq=1 Destination Host Unreachable
From 192.168.0.10 icmp_seq=2 Destination Host Unreachable
From 192.168.0.10 icmp_seq=3 Destination Host Unreachable
--- 192.168.0.22 ping statistics ---
34 packets transmitted, 0 received, +3 errors, 100% packet loss, time 34303ms
192.168.0.1 dev wlan0 lladdr ac:b3:00:00:00:00 REACHABLE
192.168.0.22 dev wlan0 lladdr ac:37:00:00:00:00 REACHABLE
After testing, my solution would be to have two loops inside of a forever loop. the first inside loop would be to do a ping on a range of ip addresses, multiple times, that would be possible for my phone. My router has reserved the first 19 ip address and I may have about a half dozen address that DHCP will assign, including my phone, starting at address 192.168.0.20. I will ping a dozen ip address once, in background mode, wait one second for response, and throw the results away as junk. I will wait eight seconds on the arp table, and run the ip neighbor
command, grep the mac address for the ip address. The router and phone will keep this same ip address unless something unusual happens. The arp table will remain in the Pi, but will change states from REACHABLE
, STALE
, and FAILED
from pings and time.
The second inside loop will ping and check the arp table every five minutes to determine if the phone is at home. With three ping 'FAILED' in a row, the phone is not at home. One 'REACHABLE', when phone is not at home, will make the phone return home (do something). There are checks to validate the ip address and return to the first inside loop if corrections are required.
#!/bin/bash
# A script to do something when Phone returns Home.
mac="ac:37:00:00:00:00" # Your phone mac address
ip_addr="" # Leave blank or ip for test
network="192.168.0.0" # Your network (Class C only)
range="20 32" # ip address possible range
pgm='echo "do something"' # program to exec when Phone returns Home
start=$(echo "$range" | cut -d " " -f1)
stop=$(echo "$range" | cut -d " " -f2)
network=$(echo "$network" | cut -d. -f1-3)
echo "Start $(date)"
while [ 1 ]; do
cnt=0
fail=0
[ "$ip_addr" ] || while [ ! "$ip_addr" ]; do
for x in $(seq "$start" "$stop"); do
(junk=$(ping -c1 -W1 "$network"."$x") & )
wait
done
sleep 8
ip_addr=$(ip neighbor | grep "$mac" | cut -d " " -f1)
((cnt++))
if (( $cnt > 15 )); then
cnt=0
echo "--- Phone not Home $(date)"
sleep 300 # 5 minutes
fi
if [ "$ip_addr" ]; then
echo "--- Phone is Home, Count = $cnt, Date = $(date)"
echo "Phone ip = $ip_addr mac = $mac"
fi
done
while [ "$ip_addr" ]; do
junk="$(ping -c1 -W1 $ip_addr)"
sleep 8
home_nw="$(ip neighbor | grep $ip_addr | cut -d ' ' -f 1,5,6)"
echo "$home_nw - $(date)"
is_home=$(echo "$home_nw" | cut -d " " -f3)
if [ "$is_home" == "REACHABLE" ] && (( "$fail" >= 3 )); then
echo "--- Phone returned Home - $(date)"
$pgm
fi
[ "$is_home" == "REACHABLE" ] && fail=0
mac_stat=$(echo "$home_nw" | cut -d " " -f2)
if [ "$mac_stat" == "FAILED" ]; then
(( "$fail" < 10 )) && ((fail++))
ip_test="$(ip neighbor | grep $mac | cut -d ' ' -f1)"
if [ "$ip_test" ]; then
[ "$ip_test" == "$ip_addr" ] || ip_addr=""
fi
if (( "$fail" == 3 )); then
echo "--- Phone not at Home $(date)"
fi
else
if [ "$mac_stat" != "$mac" ]; then
ip_addr=""
fi
fi
done
done
