I'm working on an industrial application for the Pi, and for that we need to, of course, change the username. I don't want to do this manually everytime, so I want to use a script. So far I have written a script for writing the image to the SD card and an install script that installs all the right dependencies, repositories etc. Now I have had good results changing the username manually based on the answer of Mike Lutz in this question, which states
exec sudo -s
cd /
usermod -l newname -d /home/newname -m oldname
unfortunately, this does not work if you want to use it in a script, because the script will still be running on your old username, and therefor the username can't be changed.
So what I have resorted to now, is in the imaging to SD card script, I have written the following:
NEWNAME=pareto
boot_path=/media/pareto/pi_boot
filesystem_path=/media/pareto/pi_filesystem
#check for mounted sd card => unmount
echo "Unmounting SD card"
sudo umount /dev/mmcblk0p1
sudo umount /dev/mmcblk0p2
# mount SD card partitions to the right folders
echo "Mounting SD card partitions"
sudo mount -t vfat /dev/mmcblk0p1 $boot_path
sudo mount -t ext4 /dev/mmcblk0p2 $filesystem_path
# replace username 'pi' with '$NEWNAME'
echo "Replacing all instances of user 'pi' with '$NEWNAME'"
for i in passwd shadow group gshadow sudoers; do
sudo sed -i "s/:pi/:$NEWNAME/g" $filesystem_path/etc/$i
sudo sed -i "s/^pi:/$NEWNAME:/g" $filesystem_path/etc/$i
sudo sed -i "s/\/pi:/\/$NEWNAME:/g" $filesystem_path/etc/$i
done
# change the home folders name to correspond with $NEWNAME
sudo mv $filesystem_path/home/pi $filesystem_path/home/$NEWNAME
So far it seems to work, but it feels very dirty. Is there a better way to change the username from a script (either via SSH/UART console) and if not, am I missing some important files I should change as well?
man usermodnotes, "You must make certain that the named user is not executing any processes when this command is being executed if the user's numerical user ID, the user's name, or the user's home directory is being changed." I agree w/ Steve, BTW. Further it sounds to me like what you are doing should be run as a root process. Since sudo pi has superpowers on Raspbian anyway, this would hardly be a greater risk (if that's the objection in the first place -- I dunno why you want to configure the system using a user account). – goldilocks May 05 '17 at 12:28
