I'm new to Pi and Linux, and I'm using the Pi Zero W with a fresh version of Raspbian installed. I'm trying to get PyGame installed on the Pi so that I can work on a project. When I run the command
pi@raspberrypi:~/pygame $ python setup.py
This is the output:
No Arguments Given, Perform Default Install? [Y/n]y
WARNING, No "Setup" File Exists, Running "config.py"
Using UNIX configuration...
Hunting dependencies...
sh: 1: sdl-config: not found
WARNING: "sdl-config" failed!
Unable to run "sdl-config". Please make sure a development version of SDL is installed.
What does this mean in terms of the Pi? What can I do to fix this (some terminal commands would be great, I have no idea how to use the Debian Package Tracking System)
