I have a problem regarding the uart not working at all, following are the steps as done from my side.
  1. updated and upgraded the raspberry pi,initially i installed raspbian wheezy to sd card and i am running pi over ssh.
  2. in config.txt added
    enable_uart=1
    core_freq=250
    force_turbo=1
    dtoverlay=pi3-disable-bt
  3. in cmdline.txt removed the line related to ttyAMA0, the remaining command is as follows:
    dwc_otg.lpm_enable=0 console=tty1 root=/dev/mmcblk0p rootfstype=ext4 elevator=deadline rootwait
  4. i opened the minicom and tried to see if data appears, but i was not able to visualise any kind of data. Following is the python code:
    import time
    import serial
    print "Starting program"
    ser = serial.Serial('/dev/ttyAMA0', baudrate=9600,
                        parity=serial.PARITY_NONE,
                        stopbits=serial.STOPBITS_ONE,
                        bytesize=serial.EIGHTBITS
    time.sleep(1)
    while 1:
        ser.write('Success')
        print 'Data Echo Mode Enabled'
        ser.close()
goldilocks
  • 58,859
  • 112
  • 227
As detailed in the comments, the solution is to replace "/dev/ttyAMA0" with "/dev/ttyS0" in the code, giving:
import time
import serial
ser = serial.Serial('/dev/ttyS0', baudrate=9600,
time.sleep(1)
while 1:
    ser.close()
