I've been using a Raspberry Pi with the "Simulink Support Package" for quite some time, but suddenly the USB ports start acting out. If I keep re-attaching an USB element, it suddenly connects and works, but without touching anything, not moving it an inch, the Pi suddenly doesn't recognize the hardware anymore.
Notes:
- The ethernet still works, despite the USBs acting out
- Either all USBs work, or they don't. Never just some of them.
- All hardware have been tested with a laptop, where they work fine.
- Tried reinstalling the Simulink package several times without any change in behaviour.
- HDMI still working.
Any ideas to what could cause this fault?
Edit(Clarification):
I'm trying to connect an USB-keyboard and and USB microphone. Both have been working flawlessly for the past 2 weeks.
I'm using a 5V 2.5A power supply.
My USB inputs are not showed when using lsusb.
I've tried rebooting too see if the hardware would give sign of connection briefly on startup, but no result. Sat around for some minutes without touching anything, re-plugged the keyboard, which started working for a few seconds until I plugged the microphone, from which point everything stopped working again.
My first thought was the complete bus might be at fault, but the ethernet port keeps going strong.
lsusboutput (that post is WRT to an external hub, but you can do the same thing to the internal one). – goldilocks Apr 20 '17 at 12:311-1:1.0; if you look atlsusb, the hub is the first device on bus 1, parallel to the ethernet controller, and if you look in sys, it's that that has 5 (?!) ports associated with it. – goldilocks Apr 20 '17 at 12:47/sys/bus/usb/drivers/hub/unbind, then you can issue theechofrom anywhere. – goldilocks Apr 20 '17 at 13:09
