Please suggest me in installing raspberry pi operating system without using display i.e installation through ssh
Asked
Active
Viewed 99 times
How did all the methods suggested by Google fail? Give details of every method you have used with detail of the steps at which it went wrong. – joan Apr 04 '17 at 07:15
I dont have extra monitor display so i need to install raspberry pi operating by connecting ssh through ip address – Dilip Apr 04 '17 at 07:26
1http://raspberrypi.stackexchange.com/questions/15192/installing-raspbian-from-noobs-without-display Duplicate? – kemis Apr 04 '17 at 07:29
@kemis The answer you linked was for NOOBS, not Raspbian, and NO LONGER WORKS – Milliways Apr 04 '17 at 07:44
This question is just too broad. There are at least a couple of dozen available operating systems for the Pi, each of which will have different requirements for headless installations. If you can edit your question to specify a particular OS, and the steps you've already taken to try and get it set up, I'd be happy to reopen the question. – goobering Apr 04 '17 at 08:44
it depends on the operating system that you would like to install on the Raspberry pi, you have following options as far as I know, which you dont need SSH to install operating system:
Windows 10 IOT : https://developer.microsoft.com/en-us/windows/iot
Max2Play, Raspbian based operating system: https://www.max2play.com/en/
Raspbian: https://www.raspberrypi.org/documentation/installation/installing-images/
Regards,
Mohammad Mbydeen
Mohammad Mbydeen
- 34
- 4
This is fine as it goes, but the overly-broad nature of the question makes this a fairly incomplete answer - there are a great many more than two options available for headless OS installations, including Raspbian. Given that Raspbian is likely to be the default OS of choice for the vast majority of Pi users I'd say it's a little disingenuous to leave it off the list here. – goobering Apr 04 '17 at 08:53
