I just installed a fresh SD Card with Noobs 2.3, changed to silentinstall in recovery.cmdline and did all the other steps in Installing Raspbian from NOOBS without display but now it doesn't work. The tutorial uses an earlier version of noobs so there are probably some differences, the only question is what those are..?
I can ping the rPi and can se that it obtains an IP from the router but I can't ssh to it.
ssh -v simpel@192.168.1.100
OpenSSH_7.3p1, LibreSSL 2.4.1
debug1: Reading configuration data /etc/ssh/ssh_config
debug1: /etc/ssh/ssh_config line 20: Applying options for *
debug1: /etc/ssh/ssh_config line 56: Applying options for *
debug1: Connecting to 192.168.1.100 [192.168.1.100] port 22.
debug1: connect to address 192.168.1.100 port 22: Connection refused
ssh: connect to host 192.168.1.100 port 22: Connection refused
sshworkaround does NOT (currently) work with NOOBS. – Milliways Mar 10 '17 at 07:30
