I have a Raspberry Pi 3 with an external WiFi antenna wlan1 set up as an independent IoT access point without Internet connection following this tutorial, using hostap and isc-dhcp server. I omitted the Network Access Translation part. The AP worked well up to the point when I tried connecting wlan0 to my router at home for accessing the Internet via the GUI.
My /etc/network/interfaces looks like this
auto lo
iface lo inet loopback
iface eth0 inet manual
allow-hotplug wlan0
iface wlan0 inet manual
    wpa-conf /etc/wpa/supplicant/wpa_supplicant.conf
allow-hotplug wlan1
iface wlan1 inet static
    address 192.168.42.1
    netmask 255.255.255.0
I setup the daemon
sudo service hostapd start
sudo service isc-dhcp-server start
and
sudo update-rc.d hostapd enable
sudo update-rc.d isc-dhcp-server enable
and this all worked before I started messing with wlan0.... But now on boot when hovering over the GUI it says "wlan1: Disassociated from Pi3AP" and sudo service hostapd status prints
Loaded: loaded (/etc/init.d/hostapd)
Active: active (exited) since ... 31 mins ago
Process: 571 ExecStart=/etc/init.d/hostapd start (code=exited, status=0/SUCCESS)
The command
sudo service isc-dhcp-server status
returns an error
raspberrypi dhcpd[778]: receive_packet failed on wlan1: Network is down
When I run
sudo /usr/sbin/hostapd /etc/hostapd/hostapd.conf
all works again but nothing on reboot. Can someone spot at where the error lies? Somehow the network GUI and/or the two wlan interfaces seem to be interfering with each other.
birgit
  • 71
    try to add denyinterfaces wlan1 to /ect/dhcpcd.conf. That should stop dhcpcd tying to do anything on wlan1 – Mero Feb 28 '17 at 11:56
  • @Mero Wouldn't the line iface wlan1 inet static already prevent that? – Dmitry Grigoryev Feb 28 '17 at 16:49
  • @DmitryGrigoryev As far as I know, no. dhcpcd will keep try to obtain ip address. – Mero Feb 28 '17 at 17:24
  • @Mero But then, what's the purpose of iface wlan1 inet dhcp? – Dmitry Grigoryev Feb 28 '17 at 17:32
    @DmitryGrigoryev This might answer your question. http://raspberrypi.stackexchange.com/questions/39785/dhcpcd-vs-etc-network-interfaces. So I believe dhcpcd start after networking and by default it will take over all interfaces. In order to stop that happening, you need to tell dhcpcd to do not do anything on that interface – Mero Feb 28 '17 at 17:44
  • To the OP: read this post (especially Setup a Static IP Address section) and see if that helps. – Dmitry Grigoryev Mar 01 '17 at 12:21
0 Answers0
