I need Linuxbrew for a certain application, and how can I acquire Linuxbrew?
Asked
Active
Viewed 8,918 times
It is not in the Raspbian package repository, you can verify this with:
sudo apt-cache search linuxbrew.
This is not surprising as this is a non standard way of installing packages on Linux (It is a port of Homebrew from Mac OS).
You can install from source:
ruby -e "$(curl -fsSL https://raw.githubusercontent.com/Linuxbrew/install/master/install)"
PATH="$HOME/.linuxbrew/bin:$PATH"
Edit your
~/.bash_profile
and add
~/.linuxbrew/bin
to your PATH:
echo 'export PATH="$HOME/.linuxbrew/bin:$PATH"' >>~/.bash_profile
reload your .bash_profile
source ~/.bash_profile
full instructions are available here.
Ghanima
- 15,855
- 15
- 61
- 119
Steve Robillard
- 34,687
- 17
- 103
- 109
It is but you won't be able to use it as they move to the a ruby version for 64 bits...
Install it via linuxbrew-wrapper:
sudo apt-get install linuxbrew-wrapper
Execute brew and you'll get
brew
For the convenience of using linuxbrew it is recommended to update the
following environment variables after installing linuxbrew.
PATH, MANPATH, INFOPATH
Set HOMEBREW_BOTTLE_DOMAIN environment variable if you prefer some
homebrew mirror as your upstream.
(example: /usr/share/doc/linuxbrew-wrapper/examples/profile)
==> This script will install:
/home/pi/.linuxbrew/bin/brew
/home/pi/.linuxbrew/Library/...
/home/pi/.linuxbrew/share/doc/homebrew
/home/pi/.linuxbrew/share/man/man1/brew.1
/home/pi/.linuxbrew/share/zsh/site-functions/_brew
/home/pi/.linuxbrew/etc/bash_completion.d/brew
/home/pi/.cache/Homebrew/
Press RETURN to continue or any other key to abort
After pressing return linux brew will be downloaded and installed.
Anyway, you'll get next error:
==> Pouring portable-ruby-2.3.3_2.armv6_linux.bottle.tar.gz
Error: Failed to install vendor ruby.
Error: Failed to install vendor Ruby.
Fabian
- 1,260
- 10
- 19
Pau Chorro
- 121
- 3
export PATH="$PATH:$HOME/.linuxbrew/bin"– scruss Feb 20 '17 at 22:38
