I would like to create a python program to detect when a certain key (W,A,S,D) is pressed so for example, while the w key is pressed, the def forward() is activated and when it is let go, it stops the motor. How would I do this so that as soon as the pi boots up, my keystrokes are detected and the program responds accordingly?
Example program
#!/usr/bin/python
import explorerhat
import sys, tty, termios, time
def left():
    explorerhat.motor.one.forward(75)
def right():
    explorerhat.motor.one.backward(75)
while True:
    char = input()
    if(char=="a"):
            left()
    if(char=="d"):
            right()
    if(char=="x"):
            break
    char = ""
explorerhat.motor.one.stop()
Thanks! This is to control a little robot I'm building.
Carson
  • 103
Using input(), you will need to press Enter after every keystroke. Instead, you might want to use a function that accepts keypresses, rather than lines of input. A starting point is in this question.
There are various ways to get your programme to start when the RPi boots up. Some of them are listed here.
JRI
  • 475
What about:
#!/usr/bin/python
import explorerhat
def left():
def right():
    explorerhat.motor.one.backwatd(75)
while True:
    char = input()
    if(char=="a"):
        left()
    else:
        if(char != "a")
    if(char=="d"):
        right()
    else:
        if(char != "d")
    if(char=="x"):
        break
    char = ""
Jason Woodruff
  • 431
