How can I set up my Pi 3, which is running Rasbian, so that I can connect to the internal WiFi using WiFi Direct?
goldilocks
  • 58,859
  • 112
  • 227
LC1983
  • 143
  • Have you seen this questions and answer on SE? http://raspberrypi.stackexchange.com/questions/45451/connect-to-raspberry-pi-3-over-wi-fi-direct does this help? If not could you specify where the answer doesn't solve your issue? – Deleuze Jan 30 '17 at 11:24
  • I have seen that post, however that is based on Arch Linux, which uses wpa supplicant, I would like to use Raspbian. – LC1983 Jan 31 '17 at 10:27
  • The exact same tools are available on Raspbian. The dupe accepted answer actually does not refer to any specific distro at all. – goldilocks Jan 31 '17 at 15:10
0 Answers0
