I'm using a Raspberry Pi model B (512 MB RAM) with the following touch screen and the latest image of Raspbian. The screen drivers are ok, since I can see the loading screen and the tty. If I plug in a keyboard, all is fine (textual, but fine).
The problem is that the GUI isn't loading. I have configured the automatic GUI and login through raspi-config, I think all the necessary packages have been installed (following this post), but it doesn't work. After the booting information I am stuck with a black screen with a fixed (not blinking) cursor on the top left corner. service lightdm stop brings the cursor blinking, service lightdm start gets it fixed again.
Seems to me that the X server has started correctly but I'm on the wrong virtual terminal; I have tried using chvt on all the terminals from 1 to 12 without success. Log files .xsession-error, LXDE/run.log or Xorg.0.log don't show any error (at least, none I can mark as error), but I can provide them if needed.
I've run out of option, can you help me?
Edit: dmesg|grep fbtft
[ 13.116199] fbtft: module is from the staging directory, the quality is unknown, you have been warned.
[ 13.159355] fbtft_of_value: regwidth = 16
[ 13.159375] fbtft_of_value: buswidth = 8
[ 13.159390] fbtft_of_value: debug = 0
[ 13.159403] fbtft_of_value: rotate = 270
[ 13.159416] fbtft_of_value: fps = 30
[ 13.159430] fbtft_of_value: txbuflen = 32768
dmesg|grep /dev/fb provides no result.
ls /dev/fb* shows two devices fb0 and fb1
dmesgor similar) which framebuffer device represents this screen? I suppose your Xorg server is trying to start on HDMI screen instead, that's why you don't see anything. – Dmitry Grigoryev Jan 26 '17 at 10:59FRAMEBUFFER=/dev/fbX startxwithXinfbXequal to 0, 1, etc. Eventually you'll find the right one. – Dmitry Grigoryev Jan 26 '17 at 11:03lsmodsays that modulesfb_ili9486andfbtftare loaded. – Cynical Jan 26 '17 at 11:04dmesgoutput – Cynical Jan 26 '17 at 11:05fbtftis the driver. It should create special files inside/dev/filesystem, and you need to find out which one it is. – Dmitry Grigoryev Jan 26 '17 at 11:06dmesg | grep fbtft,dmesg | grep /dev/fbandls /dev/fb*? Hopefully, there won't be much output. Or just keep tryingstartxon different framebuffers. – Dmitry Grigoryev Jan 26 '17 at 11:13FRAMEBUFFER=/dev/fb1 startx, since this page seems to suggest it's the default. – Dmitry Grigoryev Jan 26 '17 at 11:18
