I bought myself this, https://shop.pimoroni.com/products/esp8266-phat.
I started with looking through this blog post, http://richardhayler.blogspot.nl/2016/02/getting-started-with-esp8266-iot-phat.html. At point number 5.
5. We need to stop the Pi using the Serial port for console messages. Edit /boot/cmdline.txt to remove 'console=ttyAMA0' from the line. You should be left with:
dwc_otg.lpm_enable=0 console=tty1 root=/dev/mmcblk0p2 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
Instead of console=ttyAMA0
I have this console=serial0,115200
. Then, I tried with AND without console=serial0,115200
in my /boot/cmdline.txt
. I am pretty sure the serial connection is disabled as well.
As the tutorial says, I tried to run my ESP8266 pHat with minicom -b 115200 -o -D /dev/ttyAMA0
. But it does not working (after I pressed enter there is a delay and then the program closes). Since I do not have /dev/ttyAMA0
I tried with /dev/serial0
still does not working.
I tried to run installation from curl -sS get.pimoroni.com/iotphat | bash
as well but same thing happened.
I am using latest Raspbian Jessie and Raspberry PI 3 Model B
core_freq=250
in/boot/config.txt
still the same result after reboot. – notalentgeek Jan 23 '17 at 19:56ttyAMA0
is occupied by the bluetooth, andserial0
corresponds to a potentially less reliably timed "mini UART" -- but you can swap them back with a device tree overlay inconfig.txt
. Minicom seems to be "fussier" than other serial interaces such asscreen
; I'm not sure if I ever got it to work with an ESP8266. The thing with which I've had the most success isminiterm.py
, which I think you will get if youapt install python-serial
. – goldilocks Jan 23 '17 at 19:57/boot/config.txt
,dtoverlay=pi3-disable-bt
andenable_uart=1
. Thanks. – notalentgeek Jan 23 '17 at 20:11
