I have my Zero on two connections:
- Ethernet, via USB cable (with internet sharing from my laptop)
- USB wifi dongle, connected to a mobile hotspot
I believe I have successfully configured both connections.
`pi@raspberrypi:~ $ ifconfig
lo Link encap:Local Loopback
inet addr:127.0.0.1 Mask:255.0.0.0
UP LOOPBACK RUNNING MTU:65536 Metric:1
RX packets:14 errors:0 dropped:0 overruns:0 frame:0
TX packets:14 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1
RX bytes:1368 (1.3 KiB) TX bytes:1368 (1.3 KiB)
usb0 Link encap:Ethernet HWaddr f2:e8:7e:a4:ac:49
inet addr:192.168.2.31 Bcast:192.168.2.255 Mask:255.255.255.0
inet6 addr: fe80::f0e8:7eff:fea4:ac49/64 Scope:Link
RX packets:1595 errors:0 dropped:0 overruns:0 frame:0
TX packets:1062 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:158977 (155.2 KiB) TX bytes:192668 (188.1 KiB)
wlan0 Link encap:Ethernet HWaddr 18:fe:34:02:78:e5
inet addr:192.168.43.253 Bcast:192.168.43.255 Mask:255.255.255.0
inet6 addr: fe80::5dc5:b2a1:d7a:5f3/64 Scope:Link
RX packets:131 errors:0 dropped:0 overruns:0 frame:0
TX packets:138 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:11715 (11.4 KiB) TX bytes:17823 (17.4 KiB)`
`pi@raspberrypi:~ $ route -n
Kernel IP routing table
0.0.0.0 192.168.43.1 0.0.0.0 UG 0 0 0 wlan0
0.0.0.0 192.168.2.1 0.0.0.0 UG 202 0 0 usb0
0.0.0.0 192.168.43.1 0.0.0.0 UG 304 0 0 wlan0
192.168.2.0 0.0.0.0 255.255.255.0 U 202 0 0 usb0
192.168.43.0 0.0.0.0 255.255.255.0 U 304 0 0 wlan0`
I can SSH into my Pi via the ethernet connection, but not the wifi connection.
When I attempt 'ssh pi@192.168.43.253', the system just hangs.
If I ping 192.168.43.253, the ping is successful.
Here is my /etc/network/interfaces file. I suspect something is wrong with it. Perhaps my ethernet is interfering with the wifi scanning. Does anyone know what is wrong?
`auto lo usb0
iface lo inet loopback
iface eth0 inet manual
allow-hotplug wlan0
auto wlan0
iface wlan0 inet dhcp
wpa-ssid AndroidAP
wpa-psk raspberry
allow-hotplug wlan1
iface wlan1 inet manual
allow-hotplug usb0
iface usb0 inet manual`
