I have set up a new installation of NOOBS on a Raspberry Pi 2. I configured a static IP address by adding this to /etc/dhcpcd.conf:
interface eth0
static ip_address=192.168.2.102/24
static routers=192.168.2.0
static domain_name_servers=192.168.2.1
However, there doesn't seem to be any default gateway now, so I can't access the internet:
$ route
Kernel IP routing table
192.168.2.0     *               255.255.255.0   U     202    0        0 eth0
$ ping -c 1 google.com
connect: Network is unreachable
If I manually add it, everything works:
$ sudo route add default gw 192.168.2.1 eth0
$ route
default         192.168.2.1     0.0.0.0         UG    0      0        0 eth0
PING google.com (216.58.220.142) 56(84) bytes of data.
64 bytes from syd09s01-in-f142.1e100.net (216.58.220.142): icmp_seq=1 ttl=57 time=6.45 ms
--- google.com ping statistics ---
1 packets transmitted, 1 received, 0% packet loss, time 0ms
rtt min/avg/max/mdev = 6.457/6.457/6.457/0.000 ms
But this needs to be done every time I reboot. I tried adding:
auto eth0
to /etc/network/interfaces as suggested on another forum but it made no difference.
Am I missing something?
Here is the contents of my /etc/network/interfaces:
auto lo
iface lo inet loopback
iface eth0 inet manual
allow-hotplug wlan0
iface wlan0 inet manual
allow-hotplug wlan1
iface wlan1 inet manual
aco
  • 131
After a lot of fiddling and searching, I found I had a typo in /etc/dhcpcd.conf. This line:
should be:
static routers=192.168.2.1
After fixing that, everything now works.
aco
  • 131
