I have an Ethernet cable from my MacBook to my Pi. I would like to control my Pi using SSH.
If I check ifconfig on the Pi then I see my inet addr is 169.254.132.204.
Is it possible to set up an SSH connection?
I don't have any internet.
techraf
  • 4,319
clankill3r
  • 202
You can ssh from macOS to Pi even using a Link-local address with ssh pi@raspberrypi.local. See How do I set up networking/WiFi/Static IP which has a section discussing this.
Use SSH application such as PuTTY, or any. Then you can control your Raspberry by logging into it using your login ID (default: pi) and password (default: raspberry).
Their you get complete access of the terminal of Pi.
techraf
  • 4,319
  • Why do you recommend PuTTY? Is it the most appropriate application for the problem described in the question? – techraf Dec 20 '16 at 06:32
    Note that installing PuTTY on Mac OS is far from straightforward: the OP will have to install MacPorts or Homebrew first. Why not just use ssh command in terminal? – Dmitry Grigoryev Dec 20 '16 at 10:49
