I'm trying to build a TV remote control using Raspberry Pi, and I get the following error when I try to send a command:
pi@raspberrypi:~$ irsend SEND_ONCE Samsung_BN59-00937A KEY_POWER
irsend: command failed: SEND_ONCE Samsung_BN59-00937A KEY_POWER
irsend: hardware does not support sending
I've built an IR circuit, which works fine when I test it using a simple blinking script:
#!/usr/bin/python
import RPi.GPIO as GPIO
import time
print "Starting blink test.."
GPIO.setwarnings(True)
GPIO.setmode(GPIO.BCM)
GPIO.setup(17, GPIO.OUT)
while True:
GPIO.output(17, True)
time.sleep(1)
GPIO.output(17, False)
time.sleep(1)
When I run this I can see the IR LED blinking using a camera LCD viewfinder. The circuit is wired according to this tutorial.
I set up LIRC following this tutorial.
My /etc/modules has these two lines in it:
lirc_dev
lirc_rpi gpio_in_pin=18 gpio_out_pin=17
My /boot/config.txt has this line in it:
dtoverlay=lirc-rpi,gpio_in_pin=18,gpio_out_pin=17
My /etc/lirc/hardware.conf looks like this:
# /etc/lirc/hardware.conf
# Arguments which will be used when launching lircd
LIRCD_ARGS="--uinput"
#Don't start lircmd even if there seems to be a good config file
#START_LIRCMD=false
#Don't start irexec, even if a good config file seems to exist.
#START_IREXEC=false
#Try to load appropriate kernel modules
LOAD_MODULES=true
# Run "lircd --driver=help" for a list of supported drivers.
DRIVER="default"
# usually /dev/lirc0 is the correct setting for systems using udev
DEVICE="/dev/lirc0"
MODULES="lirc_rpi"
# Default configuration files for your hardware if any
LIRCD_CONF=""
LIRCMD_CONF=""
My /etc/rc.local has this line in it:
modprobe lirc_rpi gpio_in_pin=18 gpio_out_pins=17
I also tried following the suggested answer from this question and added the file
/etc/modprobe.d/ir-remote.conf
with this line in it:
options lirc_rpi gpio_in_pin=18 gpio_out_pin=17
But I still get the same error with irsend. Please could somebody help me fix this? Thank you.
EDIT: This is the output of lsmod when I remove the lirc lines from /etc/modules, /etc/rc.local, and /etc/modprobe.d/ir-remote.conf:
pi@raspberrypi:~$ lsmod
Module Size Used by
bnep 10340 2
hci_uart 17943 1
btbcm 5929 1 hci_uart
bluetooth 326105 22 bnep,btbcm,hci_uart
brcmfmac 186403 0
brcmutil 5661 1 brcmfmac
cfg80211 427855 1 brcmfmac
rfkill 16037 4 cfg80211,bluetooth
snd_bcm2835 20447 1
snd_pcm 75762 1 snd_bcm2835
snd_timer 19288 1 snd_pcm
snd 51908 5 snd_bcm2835,snd_timer,snd_pcm
bcm2835_gpiomem 3040 0
bcm2835_wdt 3225 0
lirc_rpi 6478 0
uio_pdrv_genirq 3164 0
uio 8000 1 uio_pdrv_genirq
lirc_dev 8310 1 lirc_rpi
rc_core 16468 1 lirc_dev
i2c_dev 5859 0
fuse 84037 3
ipv6 347594 46
/etc/modules,/etc/rc.local, and/etc/modprobe.d/ir-remote.conf. Then reboot and add the output oflsmodto your question. – joan Dec 04 '16 at 14:48lsmod. – Alastair Byrne Dec 04 '16 at 16:13dtoverlay=lirc-rpi,gpio_in_pin=18,gpio_out_pin=17to/boot/config.txtand rebooted. – joan Dec 04 '16 at 18:21
