Problem
I am attempting to install the drivers for this Waveshare 4inch LCD (A) touchscreen; however, after I have installed the drivers and reboot I receive the error (displayed in the HDMI monitor, not the touchscreen):
PANIC: VFS: Unable to mount root fs on unknown-block(179,2)
I am using the latest version of Raspbian (have had to reinstall three times) on Raspberry Pi 2 B.
Guide 1
At first I followed the guide on the Waveshare wiki (I used Method 1 as I did not want to install the disk image supplied on the DVD), in summary:
1) Configure RPi to auto login 2) Download and extract the driver:
wget http://www.waveshare.com/w/upload/4/4b/LCD-show-161112.tar.gz
tar xvf LCD-show-161112.tar.gz
3) Set the RPi to use the LCD display:
./LCD4-show
The system then reboots, however I get the following error message (displayed on the HDMI monitor plugged into the RPi:
I followed this answer on StackExchange editing the cmd.txt file but the problem persists (still boots up with the same error).
Guide 2
My only option was to reinstall Raspbian. I then used this answer on StackExchange which directed me to a guide to install a different set of drivers as follows:
1) Make the RPi to output the display to the SPI bus by editing the 99-turbo.conf file, changing /dev/fb0 to /dev/fb1:
sudo nano /usr/share/X11/xorg.conf.d/99-fbturbo.conf
2) Enable SPI automatic loading under advanced options in raspi-config, then reboot.
3) Download and install the drivers and reboot:
sudo REPO_URI=https://github.com/notro/rpi-firmware rpi-update
4) After reboot configure the /etc/modules and add the following:
spi-bcm2708
fbtft_device name=waveshare32b gpios=dc:22,reset:27 speed=48000000
waveshare32b width=320 height=240 buswidth=8 init=-1,0xCB,0x39,0x2C,0x00,0x34,0x02,-1,0xCF,0x00,0XC1,0X30,-1,0xE8,0x85,0x00,0x78,-1,0xEA,0x00,0x00,-1,0xED,0x64,0x03,0X12,0X81,-1,0xF7,0x20,-1,0xC0,0x23,-1,0xC1,0x10,-1,0xC5,0x3e,0x28,-1,0xC7,0x86,-1,0x36,0x28,-1,0x3A,0x55,-1,0xB1,0x00,0x18,-1,0xB6,0x08,0x82,0x27,-1,0xF2,0x00,-1,0x26,0x01,-1,0xE0,0x0F,0x31,0x2B,0x0C,0x0E,0x08,0x4E,0xF1,0x37,0x07,0x10,0x03,0x0E,0x09,0x00,-1,0XE1,0x00,0x0E,0x14,0x03,0x11,0x07,0x31,0xC1,0x48,0x08,0x0F,0x0C,0x31,0x36,0x0F,-1,0x11,-2,120,-1,0x29,-1,0x2c,-3
ads7846_device model=7846 cs=1 gpio_pendown=17 speed=1000000 keep_vref_on=1 swap_xy=0 pressure_max=255 x_plate_ohms=60 x_min=200 x_max=3900 y_min=200 y_max=3900
At this point I will note that there isn't a specific driver for the Waveshare 4inch LCD screen on here; however, the user who link the aforementioned guide stated he got his screen to work using the driver for flexfb.
In the above text I change waveshare32b with flexfb.
5) Next I edit the /boot/cmdline.txt file (I comment out the current cmdline text) and add:
dwc_otg.lpm_enable=0 console=ttyAMA0,115200 console=tty1 root=/dev/mmcblk0p2 rootfstype=ext4 elevator=deadline rootwait fbtft_device.custom fbtft_device.name=waveshare32b fbtft_device.gpios=dc:22,reset:27 fbtft_device.bgr=1 fbtft_device.speed=48000000 fbcon=map:10 fbcon=font:ProFont6x11 logo.nologo dma.dmachans=0x7f35 console=tty1 consoleblank=0 fbtft_device.fps=50 fbtft_device.rotate=0
Also, I swap waveshare32b for flexfb.
6) Finally, I set the RPi to load startx to boot automatically to the GUI with sudo nano /etc/rc.local and adding:
su -l pi -c startx
I then set raspi-config to automatically login to the desktop.
After all of this the RPi boots up but the HDMI monitor gives exactly the same error message:
Which is not healed by fixing the cmdline.txt file in recovery.
Questions
What am I doing something wrong? Does anyone have any suggestions for installing drivers to avoid this error? Or suggestions to fix the problem behind this error?
Any assistance is greatly appreciated!
Deleuze
  • 236
    PANIC: VFS: Unable to mount root fs on unknown-block(179,2) means the root filesystem isn't clean and can't be mounted. You need to fsck it. Easiest way to do that is be temporarily mounting it on another Linux system (your RPi booted from another SDCard) and running sudo umount /dev/sdb2; sudo fsck -f -y /dev/sdb2. – Dougie Apr 29 '20 at 00:04
Have you tried this on other linux PC after inserting SD card?
e2fsck -f -v /dev/mmcblk0p2
It seems your file system has been corrupted and needs to be checked.Refer to this link
Sean83
  • 201
  • Thanks Sean83, I get the following message: e2fsck: Attempt to read block from filesystem resulted in short read while while trying to open /dev/mmcblk0p2 Could this be a zero-length partition? No usbs plugged in except keyboard. – Deleuze Nov 20 '16 at 15:46
  • What is the output for this? sudo file -sL /dev/mmcblk* – Sean83 Nov 20 '16 at 17:02
  • sudo file -sL /dev/mmcblk* – Sean83 Nov 20 '16 at 17:03
This is what I followed to get mine working:
  1. use this /boot/cmdline.txt:
    dwc_otg.lpm_enable=0 console=tty1 console=ttyAMA0,115200 root=/dev/mmcblk0p2 rootfstype=ext4 elevator=deadline rootwait fbcon=map:10 fbcon=font:ProFont6x11     logo.nologo
  2. edit the end of /boot/config.txt to contain:
    dtparam=audio=on
    dtparam=spi=on
    dtoverlay=ads7846,penirq=25,penirq_pull=2,xohms=150,swapxy=1,xmin=300,ymin=700,xmax=3800,ymax=3400,pmax=255
    dtoverlay=waveshare35a
  3. copy waveshare35a.dtb (found on-line via swkim01's waveshare git hub [use a web search]) to the /boot/overlays directory as:
    waveshare35a.dtbo
(note that the new kernel requires a '.dtbo' on overlays now!)
  1. edit /usr/share/X11/xorg.conf.d/99-fbturbo.conf to contain:
    Section "Device"
    Identifier "Allwinner A10/A13 FBDEV"
    Driver "fbturbo"
    Option "fbdev" "/dev/fb1"
    Option "SwapbuffersWait" "true"
    EndSection
  2. create a file named 99-calibration.conf under /etc/X11/xorg.conf.d to contain:
    Section "InputClass"
    Identifier "calibration"
    MatchProduct "ADS7846 Touchscreen"
    Option "Calibration" "3932 300 294 3801"
    Option "SwapAxes" "1"
    EndSection
  3. reboot and enjoy!
credits to willie from : kg4zqz.blogspot.com
Brett Reinhard
  • 454
  • Hmmm, thanks again - still having the issue with the file system being corrupted... – Deleuze Nov 27 '16 at 19:49
  • @Deleuze how are you managing shutdown , and what class sd card are you using ? – Brett Reinhard Nov 27 '16 at 20:12
  • Thanks Brett, class 4 Samsung SD card - works fine when I run Raspbian without the touchscreen drivers installed. When installing drivers am using sudo reboot, once the file system is corrupted all I can do is oull the plug and eventually reinstall the OS. – Deleuze Nov 28 '16 at 14:46
  • Two things, when you first install the OS do you use sudo raspi-config and expand the filesystem. If you do I would suggest looking into making your system a read only system if what you are using your pi for will allow for such a setup. @Deleuze – Brett Reinhard Nov 28 '16 at 15:09
  • Thanks Brett - I will have a look at making the system read only and see if that helps. – Deleuze Nov 28 '16 at 15:17
