Can I record a longer video (2h+) with raspivid and store it on a USB drive (100GB+) while using a small MicroSD card (8GB)?
Specifications:
Resolution 1080p
Framerate 30fps
Format h264
I am not sure what bitrate it has by default (which is the setting I will be using).
USB drive USB 3.0 Flash Drive FIT
130MB/s (although limited by rpi:s usb 2.0)
Clone
  • 215
Should be fine.
The sample values provided here on raspberrypi-spy.co.uk suggest a bitrate of around 115MB per minute for raspivid at its default settings (1920x1080, 30 fps). That would put your storage requirements at something like 13.8GB for two hours worth of footage. The primary bottleneck is likely to be the Pi's USB bus, as you've already noted, but I don't think it'll be an issue with those settings.
goobering
  • 10,730
  • 39
  • 64
