The WiFi-related configurations are stored in /etc/wpa_supplicant/wpa_supplicant.conf file. For example, if WPS (WiFi protected setup) is succeeded by using wpa_cli command, the configuration information, such as SSID, passphrase, etc. will be stored inside it.
Now, what I want to do is to clear all the wifi configuration information inside /etc/wpa_supplicant/wpa_supplicant.conf. And what I am considering now is:
1.delete all the content in /etc/wpa_supplicant/wpa_supplicant.conf file
2.write the original information into it
3.reboot the system
But, is there any other way to reset the configuration file?
bamb00dark
  • 73
Unfortunately, there isn't a really convenient way of doing this - that is why I would recommend to always have a backup of a .conf-files original content.
Instead of deleting and re-writing the content of the file, you could just swap it altogether and than restart just the networking service:
sudo cp /etc/wpa_supplicant/wpa_supplicant.backup /etc/wpa_supplicant/wpa_supplicant.conf
sudo service networking restart
This way, you don't have to reboot.
Another way I thought of was reinstalling the wpasupplicant-package (sudp apt-get install --reinstall wpasupplicant). However, this didn't reset an altered wpa_supplicant.conf-file and is therefore not solving the problem.
Fantilein1990
  • 900
  • Backup the original configuration file, and copy it to /etc/wpa_supplicant/wpa_supplicant.conf when resetting the WiFi configuration is a good idea. Thank you – bamb00dark Nov 15 '16 at 05:02
