I am running Raspbian Jessie (the latest one in the time of posting this) and Wi-Fi drops after exactly 1 minute. And it doesn't matter if its idle or not: even when I'm pinging my Pi, it drops after a minute. My PSU is 2 amps, which is more than enough for the Raspberry Pi 3 AFAIK. When I ran the following commands, the Pi was connected to the router through an Ethernet cable, so if any info is insufficient in the logs feel free to ask in the comments.
Here's the output of iwconfig:
wlan0 IEEE 802.11bgn ESSID:off/any
Mode:Managed Access Point: Not-Associated Tx-Power=31 dBm
Retry short limit:7 RTS thr:off Fragment thr:off
Power Management:off
lo no wireless extensions.
eth0 no wireless extensions.
Output of cat /etc/network/interfaces:
auto lo
iface lo inet loopback
iface eth0 inet manual
allow-hotplug wlan0
iface wlan0 inet manual
post-up iw dev $IFACE set power_save off
wireless-power off
wireless-power off
allow-hotplug wlan1
iface wlan1 inet manual
Output of sudo tail -n 50 /var/log/syslog:
ct 30 18:02:40 raspberrypi ntpd[572]: Listen normally on 9 wlan0 192.168.1.43 UDP 123
Oct 30 18:02:40 raspberrypi ntpd[572]: peers refreshed
Oct 30 18:03:34 raspberrypi wpa_supplicant[549]: wlan0: CTRL-EVENT-DISCONNECTED bssid=b2:46:fc:61:ac:c0 reason=0 locally_generated=1
Oct 30 18:03:34 raspberrypi rsyslogd-2007: action 'action 17' suspended, next retry is Sun Oct 30 18:04:04 2016 [try http://www.rsyslog.com/e/2007 ]
Oct 30 18:03:34 raspberrypi dhcpcd[432]: wlan0: carrier lost
Oct 30 18:03:34 raspberrypi wpa_supplicant[549]: wlan0: CTRL-EVENT-REGDOM-CHANGE init=CORE type=WORLD
Oct 30 18:03:34 raspberrypi kernel: [ 199.583749] brcmfmac: brcmf_cfg80211_reg_notifier: not a ISO3166 code
Oct 30 18:03:34 raspberrypi kernel: [ 199.583787] cfg80211: World regulatory domain updated:
Oct 30 18:03:34 raspberrypi kernel: [ 199.583796] cfg80211: DFS Master region: unset
Oct 30 18:03:34 raspberrypi kernel: [ 199.583807] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp), (dfs_cac_time)
Oct 30 18:03:34 raspberrypi kernel: [ 199.583822] cfg80211: (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
Oct 30 18:03:34 raspberrypi kernel: [ 199.583835] cfg80211: (2457000 KHz - 2482000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
Oct 30 18:03:34 raspberrypi kernel: [ 199.583847] cfg80211: (2474000 KHz - 2494000 KHz @ 20000 KHz), (N/A, 2000 mBm), (N/A)
Oct 30 18:03:34 raspberrypi kernel: [ 199.583862] cfg80211: (5170000 KHz - 5250000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (N/A)
Oct 30 18:03:34 raspberrypi kernel: [ 199.583876] cfg80211: (5250000 KHz - 5330000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (0 s)
Oct 30 18:03:34 raspberrypi kernel: [ 199.583889] cfg80211: (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2000 mBm), (0 s)
Oct 30 18:03:34 raspberrypi kernel: [ 199.583903] cfg80211: (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 2000 mBm), (N/A)
Oct 30 18:03:34 raspberrypi kernel: [ 199.583915] cfg80211: (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 0 mBm), (N/A)
Oct 30 18:03:34 raspberrypi dhcpcd[432]: wlan0: deleting address fe80::608e:ea7f:768f:804b
Oct 30 18:03:34 raspberrypi avahi-daemon[425]: Withdrawing address record for fe80::608e:ea7f:768f:804b on wlan0.
Oct 30 18:03:34 raspberrypi avahi-daemon[425]: Leaving mDNS multicast group on interface wlan0.IPv6 with address fe80::608e:ea7f:768f:804b.
Oct 30 18:03:34 raspberrypi avahi-daemon[425]: Interface wlan0.IPv6 no longer relevant for mDNS.
Oct 30 18:03:34 raspberrypi dhcpcd[432]: wlan0: deleting route to 192.168.1.0/24
Oct 30 18:03:34 raspberrypi dhcpcd[432]: wlan0: deleting default route via 192.168.1.1
Oct 30 18:03:34 raspberrypi avahi-daemon[425]: Withdrawing address record for 192.168.1.43 on wlan0.
Oct 30 18:03:36 raspberrypi ntpd[572]: Deleting interface #9 wlan0, 192.168.1.43#123, interface stats: received=0, sent=0, dropped=0, active_time=56 secs
Oct 30 18:03:36 raspberrypi ntpd[572]: peers refreshed
Oct 30 18:08:22 raspberrypi dhcpcd[432]: eth0: carrier acquired
Oct 30 18:08:22 raspberrypi dhcpcd[432]: eth0: adding address fe80::52eb:a8b3:d525:be90
Oct 30 18:08:22 raspberrypi rsyslogd-2007: action 'action 17' suspended, next retry is Sun Oct 30 18:08:52 2016 [try http://www.rsyslog.com/e/2007 ]
Oct 30 18:08:22 raspberrypi kernel: [ 488.150302] smsc95xx 1-1.1:1.0 eth0: link up, 100Mbps, full-duplex, lpa 0xC1E1
Oct 30 18:08:22 raspberrypi dhcpcd[432]: eth0: IAID eb:ee:01:5f
Oct 30 18:08:23 raspberrypi dhcpcd[432]: eth0: rebinding lease of 192.168.1.64
Oct 30 18:08:23 raspberrypi dhcpcd[432]: eth0: soliciting an IPv6 router
Oct 30 18:08:24 raspberrypi avahi-daemon[425]: Joining mDNS multicast group on interface eth0.IPv6 with address fe80::52eb:a8b3:d525:be90.
Oct 30 18:08:24 raspberrypi avahi-daemon[425]: New relevant interface eth0.IPv6 for mDNS.
Oct 30 18:08:24 raspberrypi avahi-daemon[425]: Registering new address record for fe80::52eb:a8b3:d525:be90 on eth0.*.
Oct 30 18:08:26 raspberrypi ntpd[572]: Listen normally on 10 eth0 fe80::52eb:a8b3:d525:be90 UDP 123
Oct 30 18:08:26 raspberrypi ntpd[572]: peers refreshed
Oct 30 18:08:28 raspberrypi dhcpcd[432]: eth0: leased 192.168.1.64 for 86400 seconds
Oct 30 18:08:28 raspberrypi avahi-daemon[425]: Joining mDNS multicast group on interface eth0.IPv4 with address 192.168.1.64.
Oct 30 18:08:28 raspberrypi dhcpcd[432]: eth0: adding route to 192.168.1.0/24
Oct 30 18:08:28 raspberrypi avahi-daemon[425]: New relevant interface eth0.IPv4 for mDNS.
Oct 30 18:08:28 raspberrypi dhcpcd[432]: eth0: adding default route via 192.168.1.1
Oct 30 18:08:28 raspberrypi avahi-daemon[425]: Registering new address record for 192.168.1.64 on eth0.IPv4.
Oct 30 18:08:29 raspberrypi ntpd[572]: Listen normally on 11 eth0 192.168.1.64 UDP 123
Oct 30 18:08:29 raspberrypi ntpd[572]: peers refreshed
Oct 30 18:08:31 raspberrypi systemd[1]: Starting Session c3 of user pi.
Oct 30 18:08:31 raspberrypi systemd[1]: Started Session c3 of user pi.
Oct 30 18:08:36 raspberrypi dhcpcd[432]: eth0: no IPv6 Routers available
As far as I see everything in this file is related to networking.
As you can see I modified 2 lines in /etc/network/interfaces, but they still don't help.
I am not using any Wi-Fi dongle, it's the Pi 3's built-in Wi-Fi thing.
sudo tail -n 50 /var/log/syslogafter the wifi goes down and post that if anything is obviously related to wifi or networking. If you don't, you can still look back though that file for the appropriate time period (which is easy enough if the time has been set correctly at that point, but awkward otherwise). – goldilocks Oct 30 '16 at 14:07.152static ip. You may want to double check how you are doing this here: http://raspberrypi.stackexchange.com/q/37920/5538 – goldilocks Oct 30 '16 at 14:15wpa_supplicant.conf. After logging in maybe 20 times the message "wlan0: Disassociated from {SSID}" shows when hovering over the Wi-Fi symbol in the task bar and my network is no longer available in the list. Here is the strange thing: it works fine when I make an AP wit – Max N Dec 20 '16 at 10:26
