Apparently, I can enable IPv6 in two ways. To test, I first confirm it's not enabled currently.
$ ping6 -c 1 ::1
socket: Address family not supported by protocol
I then enable it immediately
$ sudo modprobe ipv6
And ping6 -c 1 ::1
now works. To enable it at boot, I append ipv6
on a single line to /etc/modules
, then reboot. However, it's unclear if IPv6 is working now.
$ ping6 -c 1 ::1
connect: Cannot assign requested address
N.B. it's a different error to the first one. If informative, the original enabling doesn't work now either.
$ ping6 -c 1 ::1
How can I enable IPv6 at boot?
EDIT
Here are the contents of /etc/network/interfaces
. It's a static IP.
auto lo
iface lo inet loopback
iface eth0 inet static
address 192.168.1.91
netmask 255.255.255.0
gateway 192.168.1.254
allow-hotplug wlan0
iface wlan0 inet manual
iface default inet dhcp
192.168.1.91
part? – Sparhawk Oct 23 '16 at 09:41dhcpcd
. But why IP4 in a question about IP6? – Milliways Oct 23 '16 at 09:46sudo modprobe ipv6
allowed that to happen. IPv6 worked fromping6
, and IPv4 was still working from my ssh session. However, IPv6 seemed to fail with the/etc/modules
tactic. I couldn't care less about IPv6 generally, but I'm attempting to installejabberd
, and apparently IPv6 is required. – Sparhawk Oct 23 '16 at 09:54ping6 ::1
works as well. Unfortunately though my/etc/network/interfaces
is only two lines (i.e., I don't use it, but I don't recommend that either) so I can't say what would be wrong there. You might try asking about this one on Unix & Linux. – goldilocks Oct 23 '16 at 12:41
