I don't know if it is a critical issue or not. But, I need to get rid of the question marks in my mind.
I recently purchased a Raspberry Pi 3 board and while I was playing with it, I realized that meminfo shows the physical memory size much less(~880MB) than 1GB (which is specified on the official site).
root@mypi:~# cat /proc/meminfo
MemTotal: 882780 kB
MemFree: 536068 kB
MemAvailable: 712180 kB
The amount of memory available to GPU is 16MB (which is the minimum allowed limit) checked twice on the related raspi-config menu item.
raspi-config -> Advanced Options -> Memory Split
Boot configuration also says that gpu_mem is 16MB.
root@mypi:~# cat /boot/config.txt | grep -i gpu
gpu_mem=16
For narrowing the problem space, here is the system info. By the way, system is up-to-date.
OS release:
root@mypi:~# cat /etc/os-release | grep PRETTY_NAME
PRETTY_NAME="Raspbian GNU/Linux 8 (jessie)"
Kernel version:
root@mypi:~# uname -a
Linux mypi 4.4.23-v7+ #913 SMP Tue Oct 4 14:16:19 BST 2016 armv7l GNU/Linux
Kernel vmsplit configuration:
root@mypi:~# zcat /proc/config.gz | grep CONFIG_VMSPLIT | grep -v ^#
CONFIG_VMSPLIT_2G=y
So, I have 2 questions:
- Where is the missing 128MB memory?
- What causes this situation?
cat /etc/os-releaseshould tell that. what the kernel version ?uname -ashould give that. this should help narrow down the probable causes. did the rpi-update actually work or produce any warnings? – Shreyas Murali Oct 12 '16 at 22:45MemTotal: 882776 kB MemFree: 126868 kB MemAvailable: 689576 kB"In normal circumstances there is NEVER a need to run rpi-update as it always gets you to the leading edge firmware and kernel and because that may be a testing version it could leave your RPi unbootable". https://www.raspberrypi.org/forums/viewtopic.php?p=916911#p916911 – Milliways Oct 12 '16 at 23:54vcgencmd get_mem arm && vcgencmd get_mem gpushow? – Milliways Oct 13 '16 at 00:08
