Is there any way to open root file browser in raspbian (like gksudo nautilus in ubuntu)?
- 429
- 3
- 10
Typing gksudo in Terminal and then hitting enter. A window named Run program will pop up.
Then typing pcmanfm on the Run text field. Pressing ok.
That worked for me.
- 429
- 3
- 10
Excellent. Good for file renaming and such. However, when you click to open a file in vi or leafpad it still won't save back to it. – SDsolar Oct 29 '17 at 01:30
- Open the Terminal
- Type
sudo pcmanfm
The root file manager opens.
- 4,206
- 24
- 45
- 69
- 161
- 2
You will find that 'mc' ( midnight commander ) is the fastest for browsing and file operations - CTRL+o will give you a root shell prompt to view output of commands. On a Pi, it's lightweight. You don't want to swap to your microSD. Invoke `apt-get -y install mc' . A number of common operations are 'hit-one-key-and-presto!' on the Function keys .
- 264
- 2
- 4
Just start your file manager as root.
Let's say your file manager is pcmanfm, then you should run these commands
pi@mypi:~$ sudo su
[sudo] password for pi:
root@mypi:/home/pi# pcmanfm 1>/dev/null 2>/dev/null &
- 1,240
- 2
- 11
- 20
In the case of accessing Environment Variables of root, user space should be changed. We can not know which variables are needed by the running process (i.e. pcmanfm). – vaha Oct 13 '16 at 10:24
Actually we can know that if we check
man pcmanfm. Your approach will replace desktop and menu entries with the ones fromrootuser, if corresponding variables are configured in/root/.bashrc. I don't really see the benefit. – Dmitry Grigoryev Oct 13 '16 at 10:48 -
I don't mean that we can not know variables specifically required by pcmanfm. I mean that to forget about this kind of concerns for ANY process we want to run, we should run it after sudo su in a generic/nonspecific manner. – vaha Oct 13 '16 at 10:58
Running sudo file-manager should be enough to start whatever file manager you have configured. Depending on your setup, you may need to run xhost + as the user who owns the desktop, to allow root processes to connect to it.
Finally, if your X configuration is really bizarre, you might need to tell the file manager which display it should use, i.e. sudo DISPLAY=:0 file-manager. Note that this should not be necessary in a normal setup.
- 27,928
- 6
- 53
- 144
sudo apt-get install gksushould work. – Huygens Oct 11 '16 at 11:23gksubut it is saying 'Xlib: extension"RANDR" missing on display ":1.0".'– opu 웃 Oct 11 '16 at 11:42sudo vi filenamejust like in Ubuntu. – SDsolar Oct 29 '17 at 01:32
