I am writing a python code to detect balls using RPi, Pi Cam, and OpenCV library. I am a newbie to RPi. How can I use Raspberry Pi standalone which works just like Arduino? Thus, there should be auto login and auto execution of a python code.
You can't use it exactly like an Arduino, or at least not easily, and it would not be very desirable to do so. The Pi is a considerably more complex piece of hardware.
Unless you are using it in a very unusual way, an Arduino does not require a login or possess the potential for such, etc., because it does not run an operating system. Instead, it is programmed with firmware.
You can enable auto-login using raspi-config
on Pi based operating systems such as Raspbian.
Execution of code at boot does not require anyone logged in. Logically enough, it's the other way around: There must be appropriate software running first in order for anyone to log in.
The first non-kernel code executed on POSIX style operating systems such as Raspbian is init, and everything else descends from this. Note that the current init system is actually systemd, but a lot of documentation refers to the older SysV style init.
In either case, the easiest method to start something at boot is via /etc/rc.local
, which is executed by the init system.
- 58,859
- 17
- 112
- 227
at the end in rc.local (beware in shell scripts&
is also used together with>
for a completely different purpose). You can try that out on the command line to get the idea. The reason for this is the rc.local script itself must complete in a few seconds, so you can't do things there that take a long time. But if they exit into the background, they can last there forever. – goldilocks Oct 04 '16 at 01:44
