How vulnerable is the Raspberry Pi without a case? I've seen the many Lego cases which look great, but I'm constantly wondering what the risk of such a case is. Will a Lego case successfully protect the Pi just like a regular case will? And what is it that a regular case protects the Pi from?
For me:
The pins, headers and external components look fragile and easily bent.
It looks easy to accidentally short GPIO pins and other conductors on the Pi by (e.g.) dropping it on a coductive surface, brushing a conductive object against it or dropping a conductive object onto it while it is powered up.
a number of the sockets, the HDMI connector in particular, are quite stiff; anything that makes it easier to grip the board edges or otherwise aid plugging/unplugging cables without exposing fragile connectors to undue forces therefore helps
Even something like the punnet goes a long way to solving those concerns. However, if you do put it in a case:
connector joins stick out of the bottom of the device, as does the SD card socket, so simply resting it on a flat case bottom could cause problems - there may be mechanical forces on the solder joins when inserting/removing cables, and it may be difficult to insert/remove SD cards or lay the device flat when an SD card is inserted
there isn't a great deal of clear space on the bottom of the device where feet / pads for it to rest on can go, so these would have to be very carefully positioned if such a solution is taken
- 519
- 3
- 5
I reckon the best case is The Punnet; it is a case made from card. You can print it yourself, fold and glue, and you will have a case in minutes. It protects the RPi from dust, which is the main threat.
Other cases may protect the RPi from light spills or unwanted electrical interference, but I don't think it is worth it given the cost of the RPi!
- 15,530
- 14
- 67
- 113
3I would say it is worth it given the low supply of Raspberry Pis. – Jun 20 '12 at 14:21
It's worth being careful for a while! – Alex Chamberlain Jun 20 '12 at 14:22
RS components has a simple hard case for ~$7. That plus the cost of a Pi plus an SD card puts the total cost at about $50 for a fully-functional PC. I am OK with that price given that price includes protection from minor bumps and scratches that are highly likely to occur on an office desk. – Joel Slowik Jun 22 '12 at 18:26
