Is there any way for me to use my laptop screen as a screen for my Pi (Model B)? The cost of a HDMI to VGA converter as well as a good monitor with HDMI connectivity are a little high.
I have a Raspberry Pi Model B. Unfortunately, the model comes only with an HDMI and Component port for output and not VGA.
As an experiment, I am trying to share the video output of the device directly to my laptop using internet.
Since, I cannot RDP without an operating system present on the device, is there an alternative solution?
Any way of using the GPIO ports provided?
Thanks in advance - Ananth
Jivings
  • 22,538
  • 90
  • 139
Ananth
  • 63
  • Display over network is a good idea. You can also do a lot by ssh from your laptop. As you say you need an OS for this. It's possible to get the Pi running without a monitor, and just doing the configuration over ssh. Many (most?, all?) popular SD card images come with ssh installed. Search for 'headless'. – Frepa Mar 22 '13 at 13:19
    Possible duplicate of Connect Pi to an old laptop screen See also: http://raspberrypi.stackexchange.com/questions/14611/how-to-set-up-raspberry-pi-without-a-monitor?noredirect=1&lq=1 – Ciro Santilli OurBigBook.com Aug 23 '16 at 07:44
You have to 1) flash to an SD card a distro like raspbian then 2) power up your Raspberry Pi and access it via SSH using a client like PuTTY on your laptop (on the same LAN) with default credentials reported in your image, for raspbian defaults are:
  • Host Name: raspberrypi
  • username: pi
  • password: raspberry
Then you can use the command line from laptop to the Raspberry Pi. If you want/have to use raspberrypi's IP and you have a router then access its backend and find the list of network devices, just look for "raspberrypi" hostname.
If you want graphical interface, you can 3) install a vnc server via command line to get all candies.
chirale
  • 226
If you have a screen with a DVI input, you may use an HDMI to DVI cable to connect the Pi, it works great.
If you have a TV with a HDMI input, you may use it as well.
Anyway, you are going to need an OS on the SD card to use the Pi.
Valentin
If you have older laptop then search for S-Video input. If you have it, then CVBS to S-VIDEO convertor should be much cheaper.
avra
  • 1,273
