I'd like to use my raspberry pi3 to automatically show some videos or pictures in a folder after boot. At the current state, even only pictures are ok, even if I'd like to have both.
For pictures I found fbi, and it works if I launch it manually. I am not able to make it run at startup.
This is the script I added in /etc/init.d/:
#! /bin/sh
### BEGIN INIT INFO
# Provides:          asplashscreen
# Required-Start:
# Required-Stop:
# Should-Start:
# Default-Start:     2 3 4 5
# Default-Stop:      0 1 6
# Short-Description: Show custom splashscreen
# Description:       Show custom splashscreen
### END INIT INFO
do_start () {
    /usr/bin/fbi -d /dev/fb0  -T 1 -noverbose -a -t 5 /home/pi/Photos/*.jpg &
    exit 0
case "$1" in
  start|"")
    do_start
  restart|reload|force-reload)
    echo "Error: argument '$1' not supported" >&2
    exit 3
  stop)
    # No-op
  status)
    exit 0
    echo "Usage: asplashscreen [start|stop]" >&2
    exit 3
esac
which I simply copied and modified the actual command. I then add it to the run level with sudo update-rc.d myscript defaults.
Now, the problem is that the images start play just before the login prompt is shown and after some seconds they get interrupted (in correspondence of the end of the boot process).
If the picture part works, I can try to move forward and add also videos (but in this second case I have other problems)
Thanks for the help.
EDIT: If I try to show only videos with omxplayer with the following script
#!/bin/sh
# get rid of the cursor so we don't see it when videos are running
setterm -cursor off
# set here the path to the directory containing your videos
VIDEOPATH="/home/pi/Videos"
# you can normally leave this alone
VIDEOSERVICE="omxplayer"
# now for our infinite loop!
while true; do
        if ps ax | grep -v grep | grep $VIDEOSERVICE > /dev/null
        then
            sleep 1;
        else
            for entry in `find ${VIDEOPATH} -type f`; do
            clear
                    # forcing output to local to avoid sounds: -o local
                    omxplayer -r -b "$entry" > /dev/null
        done
    fi
done
(called in /etc/rc.local) it works, so it is probably something related to fbi
Francesco
  • 111
Try editing the /etc/rc.local file like so
... # other initialization
exit 0
Also might need to disable boot to X in raspi-config
If you are looking to create a digitial signage solution, there are other options as well such as minibian which I personally prefer; or some others
Shreyas Murali
  • 2,416
  • Unfortunately the problem is the same. When launched at boot only the first couple of images are displayed, and then the prompt is shown. If instead after the boot I login and manually launch the script (sudo /etc/init.d/rc.local start) it correctly works. So it seems to be a boot issue (which I did not have on the old PI1) – Francesco Sep 28 '16 at 15:41
  • I've just tried with only videos and it works (see edit in my question). So, it seems a problem of fbi.. – Francesco Sep 28 '16 at 15:56
Add a sleep command in a script executed in background in rc.local to cause fbi to wait to execute until after login prompt displays
Jason
