I am currently setting up a bluetooth connectivity system for my garage to play music through. I have got the music playing and running smoothly, but I cannot figure out how get the pulseaudio daemon to run from startup or from a script. I'm hesitant to try random google searches since I don't want to break something important! I guess im just unsure how to proceed! any amount would help!
Here's the link/guide i used in case someone needs to take a look.
Setup Raspberry Pi 3 as bluetooth speaker
Thanks in advance!
    If you are using Raspbian check systemctl list-unit-files | grep pulse. If you installed pulseaudio via apt, there should be a service available already, you just have to enable it. – goldilocks Sep 25 '16 at 13:00
You could add the command to your /etc/rc.local file.
If you ever feel insecure about changes, you can backup your whole SD card to your computer's hard drive with dd bs=4M if=/dev/sdX of=/path/filename.img and restore it later with the vice-versa command dd bs=4M of=/dev/sdX if=/path/filename.img. Of course, you would have to edit them to fit your specific requirements, like device name of the SD card (sdc, sdd...) and path and filename on our computer's hard drive.
Domme
  • 375
In your /etc/rc.local file add:
su -c 'pulseaudio --start' - pi
echo connect 00:00:00:00:00:00 | bluetoothctl
before the exit 0 command.
This works if you have already paired and trusted your bluetooth device. Make sure to change 00:00:00:00:00:00 to your bluetooth device address.
Dylan
