19
gpio.py:5: RuntimeWarning: This channel is already in use, continuing anyway. Use GPIO.setwarnings(False) to disable warnings. GPIO.setup(8, GPIO.OUT) That is what I get after I run:
import RPi.GPIO as GPIO
GPIO.setmode(GPIO.BCM)
GPIO.setup(7, GPIO.OUT)
GPIO.output(7, 0)
GPIO.output(8, 0)
Is there anyway I can fix the warning?
Chetan Bhargava
  • 1,262
  • 29
LilVinny
  • 440
This code helped me get rid of the warning (the "finally" part at the end):
import time
GPIO.setmode(GPIO.BCM) # Broadcom pin-numbering scheme
GPIO.setup(6, GPIO.OUT) # output rf
# Initial state for LEDs:
print("Testing RF out, Press CTRL+C to exit")
try:
     print("set GIOP high")
     GPIO.output(6, GPIO.HIGH)
     time.sleep(5)
except KeyboardInterrupt: # If CTRL+C is pressed, exit cleanly:
   print("Keyboard interrupt")
except:
   print("some error")
finally:
   print("clean up")
   GPIO.cleanup() # cleanup all GPIO
user1231247
  • 426
You can safely ignore the warning.
As the message says add GPIO.setwarnings(False) to the start of your script to disable warnings.
GPIO.cleanup() sets any GPIO you have used within RPi.GPIO to INPUT mode. If that behaviour is desirable call the method before exiting your script.
joan
  • 71,024
  • 73
  • 106
  • Is there a way that I can repeat the script after every 5 minutes and after every loop turn the lights off. – LilVinny Sep 18 '16 at 17:01
List item
from time import sleep
GPIO.setwarnings(False) GPIO.setmode(GPIO.BOARD) GPIO.setup(7, GPIO.OUT) GPIO.setup(8, GPIO.IN)
state = "ON"
if GPIO.input(8) == 0: GPIO.output(7, GPIO.HIGH) state = “OFF” print(state) else: GPIO.output(7, GPIO.LOW) print(state)
Greenonline
  • 2,740
  • 36
