Here is my problem: I've created a stand-alone process for the raspberry pi. It runs a python script in the background using crontab, AND I've always the capability to continue working within Raspbian.
After used for a period of time (stand-aloned), when I try to plug it to a monitor to extract those files, the Raspberrypi doesn't get me to the Desktop. Just get stuck with a black image with a blinking underscore on the top left side of the screen.
I've tried other images, so there is no problem with the Raspberry Pi.
I don't know if there is any other solution to get inside, like emulating the same image (I've tried QEMU, but no luck).
Thanks for all, It should be great if I could recover the data from the microSD.
juasmilla
  • 233
If you only want to access your data from an SD card image, there is no need to emulate the raspberry Pi. You can simply mount the image (e.g. if you are using windows, rename the file extension to .img and windows should offer you to mount it on right click)
Edit: I realized this only works for ISO files.
Apparently (I am not using Windows) Ext2Read is able to read ext4 file systems in disk images.
My solution would be to start Ubuntu in a virtual machine or from a live usb and mount the image there.
lw1.at
  • 109
SOLVED
I've found the solution from this thread:
Can I view/copy the contents of an img file from Windows?
I've used this software: http://www.diskinternals.com/linux-reader/
And I could get into the Raspbian folder structure to recover files. Thanks!
juasmilla
  • 233
