I've created a shell script that is setting up things for me and my colleagues. This script is the first thing to be run on a clean Rasbian installation.
Problems:
  • at this time, the keyboard is not configured correctly, so even the simple task of running the script becomes difficult, because we don't find the special keys to enter / in the shell
  • it's easy to forget running the script
Therefore I'm looking for a way to run the script automatically at second startup (at first startup, Raspbian will resize the partition).
Since we're totally Windows-based, I only have access to /boot and I can modify files there only. Is it possible to run it with these limitations?
Other options like mounting in a VM or booting the Pi and modifying other files are just not convenient enough, so it won't be used.
Thomas Weller
  • 2,385
  • 51
  • re problem one, print a cheatsheet for your developers, that's no excuse ;) Hint: / is on the key labelled "-", the one next to the right shift key. WRT the second issue, I have the feeling that has been asked before. – Ghanima Aug 31 '16 at 19:53
  • If there's a technical solution I prefer it over an organizational solution. – Thomas Weller Aug 31 '16 at 20:09
    Check this out http://raspberrypi.stackexchange.com/questions/33817/use-boot-cmdline-txt-for-creating-first-boot-script/44950#44950 – Ghanima Aug 31 '16 at 20:14
  • I would have closed as duplicate myself after my edit were approved. Seems I'm a second too late... – Thomas Weller Aug 31 '16 at 20:48
0 Answers0
