Which Raspberry operating systems are available for download as an SD card image and what size should the SD card have to run it?
Related: Definitive list of OS, but I want ready to use SD card images only.
Thomas Weller
  • 2,385
  • 51
  • How is this different from http://raspberrypi.stackexchange.com/questions/534/definitive-list-of-operating-systems?noredirect=1&lq=1? Instead of turning this into a second highly related question, why can't you edit the other question and add the SD card details to that question's answers. Not to mention it would be shorter to go the other (list the non SD card images)way as almost all are SD card images. – Steve Robillard Aug 28 '16 at 23:19
    Having too largely identical questions that are intended to be canonical will quickly dissolve into a divergent mess. Your criteria of an SD card image adds little as most of them are distributed that way. As I said above you would be better off listing the ones that don't and adding that info to the other question. – Steve Robillard Aug 28 '16 at 23:31
Noobs
Download
Is actually an operating system installer, not an OS itself.
Raspbian
Official download.
A Debian derivative. Available as a normal version (4 GB card needed) and Lite version (512 MB).
Ubuntu Mate
Download
Based on Ubuntu.
ArchLinux
Download
Lightweight Linux distribution. Images are no longer maintained for Raspberry. Installation is done from tarballs now with manual setup of partitions and file systems, see here.
Pidora
Direct download
Fedora based. No longer maintained. For Raspberry Pi 1 only.
Fedberry
Download
Fedora based. Raspberry 2 and 3.
OpenWrt
Download
A small operating system focusing on network connectivity.
Download openwrt-brcm2708-bcm2708-sdcard-vfat-ext4.img for Raspberry Pi 1.
Download openwrt-brcm2708-bcm2709-sdcard-vfat-ext4.img for Raspberry Pi 2/3
OSMC (formerly RaspBMC)
Download
Open source media center.
Windows 10 IoT Core
Download
Can run Universal .NET Core apps.
RetroPie
Download
Turns your Pi into an arcade station.
RISCOS
Download (2 GB card needed)
OS running with small CPU and memory footprint. Is not a Linux derivative.
Plan 9
Direct download
Experimental Unix clone. Read the Newbie Guide, e.g. to know that the Del key kills programs.
OpenELEC
Download for Pi 1, Download for Pi 2
RaspBSD
Download
Based on FreeBSD 11.
Nard SDK
Download (16 MB card min, 1GB recommended)
For embedded systems, a robust in-RAM only distro.
Thomas Weller
  • 2,385
  • 51
