Am I just being paranoid
No. One of my first Pi's, a model B that is probably a little over three years old, has a very sightly loose microUSB power jack. It isn't a problem as long as I don't wrench the cord around too much, but I've been fairly careful with it, so I don't think it counts as the result of "abuse" but rather gradual degradation. Like what often happens to headphone jacks. And I am not a gorilla, honestly.
Some cases may help with putting a bit of pressure on the jacks to hold them in place but I am not so sure how much help that really amounts to. In a sense, they may increase the wear and tear if they make it impossible to grip the connector yourself while getting a cord out.
If you have the pi mounted somewhere or in an enclosure, use some kind of cable clamps or hangers to prevent the cords placing stress on the jacks.
I found the microUSB port on the Zero (not the power one, just the actual OTG port) so ridiculously tight that I've greased male connectors with a drop or two of skateboard bearing oil (high grade, synthetic, low viscosity -- note oils are non-conductive and safe with electronics) before putting them in so that I did not have to wiggle them as much getting them out. That's probably my best tip. And whenever possible, use two hands and grip that jack with your thumb.
I dont feel i can hold it many places without touching everywhere
Well, I think that is something not to get too paranoid about unless you live in a very static-y environment. Also, as long as the power is in, the outer metal of the jacks are grounded. You are not going to short anything by holding the HDMI port with two fingers. If you have a case that won't allow for that don't sweat it too much, just always be gentle.
So it was some back and forth with my other computer, if I only had an eth cable i could ssh to it instead.
– vasper Aug 28 '16 at 02:54
