I'm trying to run a process on my RPi that acts as a SerialPort echo: that is, simply log to a file every character it receives.
My RPi is connected to my Mac (or PC) by a USB>TTL cable. I confirmed the cable works by logging into the console via UART0, by using screen /dev/cu.usbserial on my Mac.
The OS is Raspbian Jessie and I have disabled serial login using raspi-config and removed the console arguments from /boot/cmdline.txt. This works since I can no longer log in via screen or putty.
I figured before writing the Python/Perl/Node code to act as the echo, I'd test out the connection first using screen.
The problem is, I assumed I could simply run screen /dev/tty1 9600 on my RPi, and then run screen /dev/cu.usbserial 9600 on my Mac (or COMx/9600 on PuTTY on my PC) and then both terminals would just echo to each other.
Both instances of screen start (the ports are open), but neither one is echoing to the other.
What am I missing in terms of configuration on the PI, or misunderstanding about serial/UART communication?
Thanks in advance, PT
SOLUTION: Milliways and goldilocks pointed out that /dev/tty1 is a terminal. Once that was cleared up I saw that serial0 is a link to ttyAMA0. However, neither of those worked. I had to go into /boot/config.txt and fix this "enable_uart=0" to "enable_uart=1". Now screen to screen works with /dev/serial0.
/dev/tty1is a console, not a serial port – Milliways Aug 25 '16 at 23:58dev/serial0depends on which OS and which Pi. The Foundation has been fiddling with firmware, and disabling serial by default on some e.g. Pi3 – Milliways Aug 26 '16 at 00:03screen. No luck. Thanks tho. If you can think of anything else I'm all ears. – Freeman Aug 26 '16 at 00:06dev/serial0exists then your problem is probably the connections. I have never usedscreenon the Pi - it doesn't seem to exist on my Pi. – Milliways Aug 26 '16 at 00:15
