I'd like to use my Pi as a home thermostat, with the control loop running in a python script. I want to run it as a daemon on raspbian (debian) at startup.
There's an example bash script in /etc/init.d/skeleton, but it seems unpythonic to mash bash and python together. There are python modules and deb packages that can help with start/stop/alert command processing:
Has anyone had success with a particular approach for daemonizing a "real-time" feedback control loop on the Pi?
hobs
  • 203
I have done this on several projects. https://bitbucket.org/dnetman99/raspberrypiprojects if you look at the gpsdpiTracker, the trackerServer.py uses the daemon class to daemonize the script. I then just use restartd to watch if it stops and restarts it, which also means it will start it after boot as well. I also have used the skeleton file for start, stop daemon, but is not necessary if you use this method.
restartd = sudo apt-get install restartd
alecxe
  • 55
Robert
  • 271
Look at the way we daemonize in the client pybit-client.
https://github.com/nicholasdavidson/pybit
That was designed to run as a daemon on small ARM boxes 24/7.
Handles logging, signal handling, start/stop scripts etc...
James Bennet
  • 291
