I've bought a nano wifi adapter at modmypi.com (this one).
It works, I checked it in a raspbmc configuration (I used raspbmc to configure it there).
Now I'm back at my wheezy distro, and I can't get it to work.
When I do a ifconfig it's there (see below).
The help page on modmypi.com had a script, but when I run that, I get this exception: "Looks like you're using the new 2012-09-18-wheezy-raspbian image. Sorry but the script will not currently set up the wifi on this image. You need to start the GUI using command startx and set it up using WiFi Config. The script will now terminate. Press any key to continue ..."
So now I am in the GUI, and started nm-connection-editor
, but it doesn't seem to get an ipaddress.
I've read about this command: dhclient -v wlan0
, and this is it's output:
sudo dhclient -v wlan0
Internet Systems Consortium DHCP Client 4.2.2
Copyright 2004-2011 Internet Systems Consortium.
All rights reserved.
For info, please visit https://www.isc.org/software/dhcp/
Listening on LPF/wlan0/00:0f:more numbers
Sending on LPF/wlan0/00:0f:more numbers
Sending on Socket/fallback
DHCPDISCOVER on wlan0 to 255.255.255.255 port 67 interval 5
DHCPDISCOVER on wlan0 to 255.255.255.255 port 67 interval 14
DHCPDISCOVER on wlan0 to 255.255.255.255 port 67 interval 18
DHCPDISCOVER on wlan0 to 255.255.255.255 port 67 interval 11
DHCPDISCOVER on wlan0 to 255.255.255.255 port 67 interval 13
No DHCPOFFERS received.
No working leases in persistent database - sleeping.
And now I don't know what to do.
This is the ifconfig
wlan0 Link encap:Ethernet HWaddr 00:0f:1more numbers
UP BROADCAST MULTICAST MTU:1500 Metric:1
RX packets:0 errors:0 dropped:0 overruns:0 frame:0
TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:0 (0.0 B) TX bytes:0 (0.0 B)
iwconfig wlan0
wlan0 unassociated Nickname:"<WIFI@REALTEK>"
Mode:Managed Frequency=2.412 GHz Access Point: Not-Associated
Sensitivity:0/0
Retry:off RTS thr:off Fragment thr:off
Encryption key:off
Power Management:off
Link Quality:0 Signal level:0 Noise level:0
Rx invalid nwid:0 Rx invalid crypt:0 Rx invalid frag:0
Tx excessive retries:0 Invalid misc:0 Missed beacon:0
/etc/wpa_supplicant/wpa_supplicant.conf
update_config=1
network={
ssid="Nerd"
psk="SECRET"
proto=RSN
key_mgmt=WPA-PSK
pairwise=CCMP TKIP
group=CCMP TKIP
Executing wpa_supplicant -i wlan0 -c /etc/wpa_supplicant/wpa_supplicant.conf
gives this:
wlan0: Trying to associate with 2a:65:11:f2:ce:97 (SSID='Nerd' freq=2412 MHz)
wlan0: Association request to the driver failed
wlan0: Associated with 2a:65:11:f2:ce:97
wlan0: WPA: Key negotiation completed with 2a:65:11:f2:ce:97 [PTK=CCMP GTK=TKIP]
wlan0: CTRL-EVENT-CONNECTED - Connection to 2a:65:11:f2:ce:97 completed (auth) [id=0 id_str=]
wlan0: CTRL-EVENT-DISCONNECTED bssid=2a:65:11:f2:ce:97 reason=0
wlan0: Trying to associate with 90:00:4e:87:c8:cf (SSID='Nerd' freq=2412 MHz)
wlan0: Associated with 00:00:00:00:00:00
wlan0: CTRL-EVENT-TERMINATING - signal 2 received
iwconfig wlan0
would be useful. – Arne Mar 10 '13 at 09:42iwconfig wlan0
– Michel Mar 10 '13 at 14:04/var/log/messages
if there is any output from wpa_supplicant there? – Arne Mar 10 '13 at 14:40sudo cat /var/log/messages | grep -i *wpa_*
and it returned no results – Michel Mar 10 '13 at 15:06/etc/wpa_supplicant/wpa_supplicant.conf
exists and contains your WPA encryption settings, and if they are correct. If they do, you can runwpa_supplicant -i wlan0 -c /etc/wpa_supplicant/wpa_supplicant.conf
manually, and see if it works. – Arne Mar 10 '13 at 15:10
