I am currently trying to configure two Raspberry Pi 3s. The first one works fine. However, the other one always renames eth0 to eth1 on boot.
dmesg | grep eth
[2.485760] smsc95xx 1-1-.1:1-0 eth0: register 'smsc95xx' at usb-3f980000.usb-1.1, smsc95xx USB 2.0 Ethernet, b8:27:eb:56:b6:06
[4.742863] smsc95xx 1-1.1:1.0 eth1: renamed from eth0
[4.794234] systemd-udevd[151]: renamed network interface eth0 to eth1
Both Raspberrys have the same image on their SD card with minimum non-OS modifications in custom scripts (datalogging from sensors). Both SD cards' OS instances get their correct IPs (assigned by MAC) from the DHCP server when using the first Pi. Neither get any address when installed in the other Pi. Both Pis are new and from the same seller.
Changing eth0 to eth1 in /etc/network/interfaces works around the problem, but it took me hours to find out because I didn't expect the LAN port to NOT work out of the box. Something hardware-related seems to cause unnormal behaviour even though both Pis are the same generation.
Why does the hardware have such an effect on the OS and how can I fix it?
rpi-update? – Milliways Aug 08 '16 at 11:56auto eth0toauto eth1, only changed the iface line before... now it works, still a highly confusing and massively time-consuming phenomen. One would have thought that all Pis are equal, but this one seems to have different hardware. – Domme Aug 08 '16 at 12:26Oh, and on the other Pi everything is working after all! With the same configuration except for my custom scripts for datalogging.
– Domme Aug 08 '16 at 12:50
