I have a couple of RPI which I use regularly. Recently, I have been seeing Red and Green light blinking on my RPi. Rpi works great. I just couldn't understand why both the lights are blinking as it should be red constant and green blinking on a normal scenario. Just wondering if anyone has faced the same issue.
            Asked
            Active
            Viewed 1.0k times
                    2Your power supply is inadequate. See Raspberry Pi Power Limitations The Pi itself will work with low voltage, but peripherals may not. – Milliways Aug 05 '16 at 05:13
            The most common causes of your problem are an inadequate power supply or an SD card that isn't written properly, or isn't functioning properly.
        Mohammad Ali
- 2,383
- 11
- 18
