I've been trying for a few days now to set a static IP for my Pi but have so far been unsuccessful.
I have a Model B Revision 2.0 (revision code 000d). I'm running Jessie Lite released 2016-05-27.
Previously I used to set an IP in /etc/network/interfaces but I have now read from multiple sources that the correct way is to edit /etc/dhcpcd.conf. Some sources suggest only to edit dhcpcd.conf, some suggest editing both. I have tried both.
Currently I have the following...
auto lo
iface lo inet loopback
auto eth0
iface eth0 inet static
address 192.168.1.10
gateway 192.168.1.1
netmask 255.255.255.0
network 192.168.1.0
broadcast 192.168.1.255
/etc/dhcpcd.conf
interface eth0
static ip_address=192.168.1.10/24
static routers=192.168.1.1
static domain_name_servers=192.168.1.1
#controlgroup wheel
# Inform the DHCP server of our hostname for DDNS.
hostname
# Use the hardware address of the interface for the Client ID.
clientid
# or
# Use the same DUID + IAID as set in DHCPv6 for DHCPv4 ClientID as per RFC4361.
#duid
# Persist interface configuration when dhcpcd exits.
persistent
# Rapid commit support.
# Safe to enable by default because it requires the equivalent option set
# on the server to actually work.
option rapid_commit
# A list of options to request from the DHCP server.
# Most distributions have NTP support.
option ntp_servers
# Respect the network MTU.
# Some interface drivers reset when changing the MTU so disabled by default.
#option interface_mtu
# A ServerID is required by RFC2131.
# Generate Stable Private IPv6 Addresses instead of hardware based ones
slaac private
# A hook script is provided to lookup the hostname if not set by the DHCP
# server, but it should not be run by default.
nohook lookup-hostname
With the above set, the Pi ends up with two IP addresses. Ouput of "ip addr":
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1
inet6 ::1/128 scope host
link/ether b8:27:eb:fd:ea:5e brd ff:ff:ff:ff:ff:ff
inet 192.168.1.10/24 brd 192.168.1.255 scope global eth0
inet 192.168.1.127/24 brd 192.168.1.255 scope global secondary eth0
inet6 fe80::ba27:ebff:fefd:ea5e/64 scope link
I've also tried stopping DHCP with the following: sudo update-rc.d -f dhcpcd remove
But after a reboot it still ends up with two IPs.
Edit: Forgot to mention, this is a wired connection. No wireless.
Edit: I know that I shouldn't have to edit both files. The above configuration is the last in a long series of combinations tried for the sake of trying everything.
If I edit only the interfaces file, it get two IPs. If I edit only the dhcpcd.conf file, It gets one IP assigned by dhcp (not the static one I've set).
sudo update-rc.d -f dhcpcd remove does not stop dhcp after a reboot.
sudo systemctl stop dhcpcd.service crashes the Pi and has no effect after pulling the power and plugging in again.
How can I stop DHCP?
