I made Bash script what running fan for cooling. PIN20 is PWM out and this script work perfect. I run this script over therminal arroun 15 hours.
Afer all tests i register script for autoload after reboot like this:
$ sudo cp rpipwm.sh /etc/init.d/rpipwm.sh
$ sudo chmod +x /etc/init.d/rpipwm.sh
$ sudo update-rc.d /etc/init.d/rpipwm.sh defaults
After last line I get this error: update-rc.d: error: initscript does not exist: /etc/init.d//etc/init.d/rpipwm.sh
After that error I update with this:
$ sudo update-rc.d rpipwm.sh defaults
And reboot.
After reboot my script start to work and all is fine arround 20min. After that time my script stop to work. If I run this manualy on terminal script can work hours and hours with no errors.
What's mistake?
Here is my script.
#!/bin/bash
### BEGIN INIT INFO
# Provides: rpipwm
# Required-Start: $local_fs
# Required-Stop: $local_fs
# Default-Start: 2 3 4 5
# Default-Stop: 0 1 6
# Short-Description: rpipwm
### END INIT INFO
FLAG="/var/log/rpipwm.log"
if [ ! -f $FLAG ] ;
then
a="echo 20 > /sys/class/gpio/unexport;"
a=$a"echo 20 > /sys/class/gpio/export;"
a=$a"echo out > /sys/class/gpio/gpio20/direction" || true
eval $a
#start loop script
i="0"
temp="0"
while true;
do
i=$(($i+1))
#Read temp
if [[ $(bc <<< "$i > 10") == 1 ]] ;
then
cpuTemp0=$(cat /sys/class/thermal/thermal_zone0/temp)
cpuTemp1=$(($cpuTemp0/1000))
## cpuTemp2=$(($cpuTemp0/100))
temp=$cpuTemp1
i="0"
fi
a=""
#If temperature is equal or lower than 39.99, the fan will stop spinning
if [[ $(bc <<< "$temp < 39") == 1 ]] ;
then
a=$a"echo 0 > /sys/class/gpio/gpio20/value"
fi
#If temperature is between 40 and 42.99, the fan will start with 1 second burst and 1 second sleep
if [[ $(bc <<< "$temp >= 40 && $temp <= 44") == 1 ]] ;
then
a=$a"echo 1 > /sys/class/gpio/gpio20/value; sleep 0.5; echo 0 > /sys/class/gpio/gpio20/value; sleep 0.1 "
fi
#If temperature is between 43 and 47.99, the fan will start with 1 second burst and 0.5 second sleep
if [[ $(bc <<< "$temp >= 45 && $temp <= 49") == 1 ]] ;
then
a=$a"echo 1 > /sys/class/gpio/gpio20/value; sleep 1; echo 0 > /sys/class/gpio/gpio20/value; sleep 0.5"
fi
#If temperature is equal or higher than 48, the fan will start spinning constantly
if [[ $(bc <<< "$temp > 50") == 1 ]] ;
then
a=$a"echo 1 > /sys/class/gpio/gpio20/value"
fi
eval $a
sleep 0.1
done
touch $FLAG
fi
UPDATE
I reorder script, put log in script and now have all to work properly and with no unexpected stop or break.
#!/bin/bash
### BEGIN INIT INFO
# Provides: rpipwm
### END INIT INFO
PATH=/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/home/wc3/palert
if [ ! -f $FLAG ] ;
then
eval $a
#start loop script
i="0"
temp="100"
while true;
do
i=$(($i+1))
#Read temp
if [[ $(bc <<< "$i > 5") == 1 ]] ;
then
temp=$cpuTemp1
i="0"
fi
a=""
if [[ $(bc <<< "$temp <= 39") == 1 ]] ;
then
fi
then
fi
if [[ $(bc <<< "$temp >= 45 && $temp <= 47") == 1 ]] ;
then
fi
if [[ $(bc <<< "$temp >= 48") == 1 ]] ;
then
fi
eval $a
sleep 0.1
done
touch $FLAG
fi
) &> /home/pi/rpipwm.txt
initscript to control this, you just put the script ininit.d. The scripts in theinit.ddirectory are used to start/stop/etc. some other daemon and then they exit. If they do not finish soon enough (I'd guess the value of "soon" on you system is 20 minutes), theninitdecides they are malfunctioning and kills them. I think you need to read up more on how init scripts are supposed to work. – MAP Jul 21 '16 at 08:34$aand useeval $arather than execute the commands directly? And why don't you compare with-gtand-lt– Dmitry Grigoryev Nov 10 '16 at 15:55
