I have a problem with disabling any USB ports with the command: sudo sh -c "echo 0 > /sys/devices/platform/soc/3f980000.usb/buspower" Nothing happens at all, though the content of the file IS changed to 0x0 or 0x1.
When entering
the LED of the webcam I'm trying to turn off flashes of and on for about half a second so it is affecting the USB ports in some way.
Thanks in advance!
Pontus Drejer
Here is a related question where we discussed an app that allows control of USB ports from the command-line.
tlhIngan
  • 3,372
Because it's impossible to disable the usb power, I've used udev rules and a script installed in /usr/local/sbin (tested on Raspberry PI3)
The script :
 \#!/bin/bash
 ROOTUSB=/sys/devices/platform/soc/3f980000.usb/usb1/1-1
 \#Exceptions network device
 EXC="1-1.1 1-1:1.0"
 for host in $ROOTUSB/*
 do
if [ -f $host/authorized ];then
disable=1
\# Parse exception to allow them to be enabled (network...)
for device in $EXC
do
\# If host ending equal excetion =>> dont change state
[[ $host =~ \/$device$ ]] && disable=0
done
\#Otherwise change state ==> disable
if [ $disable = 1 ];then
\#USB host to disable
echo 0 >  $host/authorized
fi
fi
done
The udev rules
 /etc/udev/rules.d/10-disableusb.rules
ACTION=="add", SUBSYSTEMS=="usb", RUN+="/usr/local/sbin/disable-usb.sh"
Refresh udev rules
udevadm control --reload-rules
Plug in a storage usb device, now, you are not allowed to enumerate filesystems
Bex
  • 2,929
  • 34
dhenry
  • please read the other answer! There is a way of controlling the power and it's by using the feature that check if the USB port is shorten or not, check https://github.com/codazoda/hub-ctrl.c – MatsK Sep 11 '17 at 16:56
