I'm attaching a fan to the RPi's original case. I wanted to use a laptop cpu fan. Should I suck the hot air from RPi? or blow cold air inside the case? Btw, there's a heatsink on the Soc and LAN & USB chip.
8Just in case there's any confusion: If you want to do this, that's fine, but unless there's some peculiar reason why you need to do this based on observed temperature of the SoC's internal sensor, beware it probably won't make any real difference to the Pi itself. – goldilocks Jul 10 '16 at 19:34
It doesn't matter. Either way you are moving air one place to the other. Cooling is about volume of air, not the direction of travel (in the sense of "push into" vs. "pull out of", ie. the direction the fan faces).
In theory, pulling air out may create negative pressure inside the case which, in theory, may be advantageous to cooling, however, in reality this is not going to happen unless your fan is a jet engine, which will probably have very detrimental side effects on the case and things within.
A more pragmatic concern on desktop cases is accumulation of dust inside because of all the moving air. However, by pushing the air in instead of out you can keep the interior clean by including a dust filter on the outside of the fan -- then you just have to vacuum the dust filter occasionally. Trying to use filters the other way around, unless you have some kind of special case, is impossible; if you are blowing air out you will end up sucking it in from some arbitrary crack, gap, or hole and dust will coat components in between there and the output fan.
With a pi sized case dust accumulation won't add up to much hassle, of course.
- 58,859
- 17
- 112
- 227
7On the contrary, I have had excellent success cooling my Pi with a small jet engine. :) – cat Jul 11 '16 at 01:02
1I'm confused ... You want to create Positive pressure (as in pressure higher than outside of the box) to increase convection right ? – Antzi Jul 11 '16 at 01:29
@Antzi I hadn't thought of it that way -- I'm no physicist and it was a joke based on the idea that temperature drops with pressure. I am serious about positive pressure being in general better WRT computer cases and dust though (works terrifically, in fact). And, taking the overheating issue seriously, accumulating dust certainly won't help, it's like slowly adding insulation. – goldilocks Jul 11 '16 at 02:22
Oh I didn't saw it this way :p Indeed, compressing air would create heat and far more outweighs any convection gain – Antzi Jul 11 '16 at 02:46
3You always want to blow air into a case, not suck air out of it. You are relying on a pressure differential to close the flow loop through the case, and the fan can raise pressure more than it can drop it. – David Schwartz Jul 11 '16 at 06:51
@DavidSchwartz It is useful to use both in conjunction in bigger cases, though - it helps create a good, steady path between the intake and the outtake, ideally across all the high-heat components. This isn't useful in, say, a car engine, since the whole airflow goes over the engine, rather than through a mostly empty body filled with "random" cables and stuff, and it likely isn't useful in a Pi case either (unless you have many Pies in a rack or something). – Luaan Jul 11 '16 at 13:41
1@Luaan Agreed. You can also get into trouble with a big case if you have too many fans trying to pull air out of the case and not enough pushing air into it. Pushing sufficient air into the case is critical. – David Schwartz Jul 11 '16 at 17:35
It doesn't matter. Either way you are moving air one place to the other. Cooling is about volume of air, not the direction of travel.Hardly. Not only do you have to deal with basic physics like hot-air rising, but the fact that most *PI cases are small and usually have limited airflow and few holes further complicates the matter. They're definitely not equivalent. – Synetech Oct 22 '21 at 02:48 -
I'll stick to my basic physics guns on this one. Given a scenario X that involves blowing air in being more effective than blowing an identical volume of air out one could always postulate an inverse scenario X' where the opposite is true -- for the example involving hot air rising where blowing in from the top is less effective, the inverse is sucking out at the bottom is also less effective (if the question, as here, is either actively push in or suck out). So all else being equal, there is no argument to be made that one direction is inherently more effective ("out is always better"). – goldilocks Oct 22 '21 at 14:26
...I suppose that is a way of saying direction does matter, but it isn't "in" or "out", since both imply through, and which way through does matter (bottom to top is probably more effective). To me the question boiled down to, "If I have only one fan, is it better to mount it facing in or out?", to which the answer is "that depends on other factors", ie., in or out is not independent in the way that volume/velocity is. – goldilocks Oct 22 '21 at 14:49
The answer is: You should direct the cold air stream directly onto the heatsink.
There are usually arrows stamped on the fan casing that shows the direction of blades rotation and the direction of air flowing through the fan when it is turned on. Install the fan such that the air flows directly onto the hot surface.
Moreover, in every similar situation (if you have a stream of fluid that you want to use for cooling of a hot surface), make sure you are directing the fastest part of the stream right onto the hottest spot. That would give the best possible result.
Here is why:
There are three general mechanisms of heat transfer:
- Heat Conduction - when the energy is transferred by collisions between particles (molecules, atoms);
- Heat Convection - when the energy is transferred from one place to another by using the moving fluid (air, water etc) as a transport environment; There are two types of convection - free and forced.
- Heat Radiation - when the energy is transferred by emitting or absorption of electromagnetic waves;
When we want to transfer the heat from a hot surface (like the heat sink surface, or the IC chip surface) to the surrounding air with the use of airflow, we are creating a forced convection condition. That is, the air stream 'takes' the molecules of air above the hot surface and move them out into external space.
In general case, the effectiveness of such heat transfer mechanism depends on the speed of the air flow that 'takes' the hot molecules and throws them away, because, the more of hot molecules we can remove from the above of surface, the cooler it will be.
We need to analyze the velocity distribution of the air streams that can be generated in different scenarios of fan placement. For that, let's name the fan sides first: the 'back' of the fan is the side where the air is sucked in. And the 'front' of the fan is the side where the air is blown out. Also, let's assume that there is a heat sink attached to the IC.
Now, let's compare the following two cases.
For a scenario, where fan is attached to the hot surface with its back (so that it is sucking the air onto the hot surface from the sides of the heat sink, perpendicular to the fan axis and blowing out the sucked air into external space through its front), the velocity of the air flow near the hot surface will be slower than the velocity of the output stream that is blown away at the front of the fan.
For a fan that is attached to the hot surface with its front side (so that it is sucking the air through its back, then throws it down directly onto the hot surface and then the air is blown out through the sides of the heat sink), the maximum flow velocity would be right at the hottest spot giving the optimal conditions for the cooling.
- 51
I tested this with non-original acrylic case and it seems there are slightly better results with pushing cold air into the box. See this video with graph: https://youtu.be/N6keyV-gOzQ
- 41
IBM and HP did a lot of research on this topic in the 60s and 70s. Blowing air in cools the hottest part best, but sends that heat to other parts thereby heating them up and lowering the overall MTBF. Sucking avoids this problem provided the fan is mounted by the hottest parts, but doesn't cool quite as well.
And dust accumulates either way. It always will when you have cold surfaces with an airflow.
- 141
- 6
As the hot air tends to get stuck inside the case i would guess sucking it out is more effective. Either way, you should make sure there's enough holes besides the fan for air to circulate.
- 518
- 2
- 11
4The "getting stuck" problem is about air not circulating to the entire case; depending on case design and fan location, this could occur with negative pressure, positive pressure, or both. – Mark Jul 11 '16 at 01:28
Look at the configuration of desktop PC cases - they all have fans that suck air out, and some also have fans that blow air in.
Case fans are always at the back, blowing air out; PSUs blow air out; graphics cards blow air out.
Some rackmount servers have fans in the middle - acting to both blow and suck at the same time!
The trick is good airflow (which is also why some have 2 sets of fans) - if you can seal the rest of the case, and provide a good path for air to be brought in (usually at the front) and blown out (usually at the back) then you get the best cooling for the least amount of air movement. If you can restrict the air intake to a certain area, then you can also put dust filters in place.
You can see this in thin 1U rackmount servers, where the fans are tiny and designed to take air in the front and blow it directly out the back over whatever components are carefully positioned in the flow.
- 101
- 2
"they all have fans that suck air out" -> Very often, but this is a bad design that continues because of the inertia of tradition; see my comments about dust and creating positive pressure by blowing a greater volume of air in than you suck out. As David Schwartz observes there in a comment, this is also more likely to ensure there are no dead spots anywhere. I.e., if you use multiple fans, the biggest one should be the input. Trying to "seal the rest of the case" is a fool's errand. – goldilocks Jul 11 '16 at 12:28
1Back when I was building PCs, we were advised that we should draw the air out of the top of the case, and push it in the bottom, so we didn't have to fight against heat rising to the top, so that PSU fans would tend to push out, simply because they usually ended up at the top in almost all of the case designs available. – SeanC Jul 11 '16 at 13:17
@SeanC I think this is why traditionally cases come with one small fan that blows out -- because it's mounted at the top on a small grate, likewise with the PSU (additionally, you wouldn't want a PSU blowing in because that air will be heated by the PSU). Then the cases come with a big open grate at the bottom >_< The best thing to do with something like that would be to add a second fan on that bottom grate (w/ outer dust filter) that has a significantly higher CFM rating than the top one. Of course we've gotten way off topic here WRT the Rpi...one fan is overkill, never mind two. – goldilocks Jul 11 '16 at 13:29
@goldilocks Obviously not hermetically sealed, but look at the server cases - air flows in the front and out the back in a clear path. Anyway, for the Pi, surely a fan is either: way too big for the case or way too small and thus noisy. Maybe the best solution is a better way to let heat provide the cooling airflow naturally - by allowing it to flow over or through the case under its own convection. – gbjbaanb Jul 11 '16 at 15:12
I've never worked with rack servers but if they are using multiple fans, some in and some out, they are likely creating positive pressure -- which is what I'm recommending. Then you do not need to seal anything. My tower case is on the floor often surrounded by dust bunnies, but pristine inside. Years ago I couldn't be bothered buying an extra fan, left the stock one in the "blow out" position, and used a dust cover on the front grill, then tried to seal the rest of the case with all manner of duct tape, etc; it's a waste of time if you are actively blowing out but not in. – goldilocks Jul 11 '16 at 15:24
One place dust loves is the grooves on heat sinks. WRT to the pi, unless you are are overclocking, you shouldn't need any fan at all and even the heatsinks are probably more fetish than anything. Anyway, you can monitor the core temp to determine this. If it idles at ~45 C and maxes out at 55-60 C it's fine as is. Most contemporary smartphones and tablets have processors on par or better than a Pi 3 and have no ventilation or cooling. – goldilocks Jul 11 '16 at 15:24
1@goldilocks look at the link - its a image of an empty rackmount case. As for grooves on heatsinks - if the fins are horizontal, there's nowhere for dust to accumulate (ie stick out to the sides to air can rise between them). My case at home has a dust filter at the lower front, and the usual gfx, psu and case fans blowing out the back - there is very little dust inside but the dust filter gets covered in gunk, so I think the important aspect is the filter, without that you're going to be sucking dust in regardless of the in/out fan configuration. – gbjbaanb Jul 11 '16 at 15:40
Point taken and YMMV with cases and heatsinks, but I still think you'd be better off turning the case fan around ;). The PSU and GPU should blow out since they are generating their own heat. – goldilocks Jul 11 '16 at 15:50
@goldilocks possibly... but the case fan would only end up sucking in hot air blown out by the PSU and GPU! I doubt it'd make any difference either- not unless the front case fan could suck in more air than they blow out to create a differential. Next time I build a PC I'll give it a go. Cheers. – gbjbaanb Jul 11 '16 at 18:58
Comment on rack servers. Air comes in the front and out the back. This is done so data centres can properly provide fresh cool air, and extract heated air in the most efficient way possible. – Stese Nov 22 '17 at 10:00
@SeanC, I asked this exact question about PCs back when SuperUser was still new and the results came back exactly that, intake at bottom and vent at top. – Synetech Oct 22 '21 at 02:46
